Del sol rough idle?
Old Jul 3, 2012 | 04:42 PM
memphosfinest's Avatar
Default Del sol rough idle?
Im working on a 1994 del sol si with the d16z6. I have changed the plugs,cables entire distributor, fuel filter and cleaned both the IACV and FITV. Car runs fine while driving but when you come to a stop or let the car idle it shakes and acts like it has a miss. Checked that the injectors are pulsating and that there is good fuel pressure. Only CEL is for primary O2 sensor. I have read the FAQs and i have checked for vacuum leaks. Thanks in advance, heres the video:
http://youtu.be/uSVgOQ1V58k
Old Jul 3, 2012 | 04:48 PM
Prboy's Avatar
Default Re: Del sol rough idle?
Had the same problem. Check ur timing, if keeps doing it raise ur idle a lil bit. Also i put seafoam in the gas tank
Good luck
Old Jul 4, 2012 | 12:26 AM
cafine's Avatar
Have you change your spark plug at all? Any engine check light pop up?
It might be a easy bad earth, or blocked injector. Or try to adjust your idle screw.
Old Jul 4, 2012 | 07:16 AM
Former User's Avatar
Fix the O2 sensor code, replace the PCV valve, and adjust the idle speed.
Old Jul 4, 2012 | 08:01 AM
motegicivic's Avatar
How many miles on it?
Check your compression.
Also adjust the valves, sounds a little noisy.
Old Jul 4, 2012 | 08:23 PM
169k . Compression is good and adjusted the idle screw and new PVC valve. No change.
Old Jul 4, 2012 | 08:27 PM
Did you exactly follow the service manual procedure in the diagram?
What O2 sensor code do you have? Fix it.
shady3260
Jul 23, 2010 10:50 PM
MisterWise
Nov 8, 2008 06:00 AM
DelSolSi93
32
Apr 23, 2004 06:57 PM
pdiddy
Dec 10, 2002 10:47 PM
