Replacing Flywheel - can I use the old pilot bearing?
So I'm installing a new clutch an flywheel on my b16a, can I used the old pilot bearing an the flywheel shim. Or should they be replace. Thanks for the help.
That's like asking if you need to replace your oil filter when you're doing an oil change. It's simple, it's cheap, and it's the smart thing to do.
http://www.autozone.com/autozone/par.../N-jdpo5Z6o24r clutch relese bearing 8.99 ship 2 home
The Flying Dutchmen
Sep 9, 2007 09:34 AM
