K24A2 oil pump timing procedure???
Old Jul 2, 2012 | 04:42 PM
dkboyny11's Avatar
Default K24A2 oil pump timing procedure???
Looking to time the oil pump on a K24/K20 build with me using the tsx style balance shaft oil pump. Anybody know how to line up the one black link in the chain and the double black link???
Any help is greatly appreciated
Old Aug 28, 2012 | 02:34 PM
93supercoupe's Avatar
Default Re: K24A2 oil pump timing procedure???
bump i need to know too!
Old Aug 29, 2012 | 10:25 AM
Gearspeed-Performance's Avatar
The oil pump gear has a line that you match on the housing. The chain itself has no markings for timing. IIRC
The main chain for the cam gears has a black link on each side of the dot on the cam gears when at TDC. The crank pulley gear for the chain has a dot that lines up with the single black tooth on the gear.
Old Aug 10, 2018 | 04:46 AM
Gpdickert's Avatar
Is this how you did the oil pump chain? Or am I backwards?
Fred Demara
Sep 12, 2012 09:18 AM
victoriasamantha
May 3, 2006 07:34 PM
h22 civic
Feb 9, 2006 01:22 PM
