Tial, Blox, Prof, DC Sports, AEM, Skunk2, Benen, GSR, B16, LS, Turbo stuff, +more
Who is Mr Robot?
I was in a very bad car accident and as a result am physically unable to work.. I'm trying to sell some of my stuff I have accumulated over the years to cover my medical expenses and living expenses. All prices do not include shipping. I am paypal verified, all paypal transactions will incur the typical paypal fee. I am open to offers but don't lowball me to death. No warranty is expressed or implied on any part unless otherwise stated. I AM OPEN TO ALL REASONABLE OFFERS
I am open to trades (NO FAKE, CHINA EBAY PARTS). I am looking for such things as aftermarket b16 springs and retainers, 1000cc injectors, GSC T1 cams, a decent catch can, aluminum half radiator, 70mm throttle body, ek solid engine mounts, ek coupe carbon fiber stuff, fastline extended shifter, steering wheel hub adapter (no eBay/NRG), moroso b series oil pan, b series harmonic dampener (ati or fluidampr), new obd2 oil pump, b series acl rod and ,aim bearings, blow off valves, wastegates, or anything cool that's turbo related or super JDM, or that will fit 96-00 civic coupes.
I will be adding more as I go through my garage/storage units. I have 2 ls heads and 2 sets of ls cams about to go up, turbos, etc.
Automatic p08 converted to a manual p28. Conversion and chipping was done professionally. ECU is socketed so you can swap chips but does not have a zif socket (standard insert and remove socket)
For some reason the part number sticker was removed off of the side but it is a 37820-P08-A51 as the sticker on top of the ecu plugs is still present.
Was removed off of a working car and has a stock b16 map in it. Unsure of what software the chip is running but the ECU does work
125obo
Benen front lower subframe bar (black) and front crossmember support bar (silver)
These are brand new, never installed on a car. Silver crossmember bar is still in bag, comes with Benen hardware, fits integra's and civic hatchbacks only (no coupes). Benen front lower bar was removed from bag to check ground clearance only, will not work for me as I'm way too low. Comes with benen hardware still in bag
Both bars traded for AEM EMS
Tial 46mm wastegate, has idle time only. Narrow body unit for more clearance. Comes with air fittings, fire ring and inlet/outlet bolts. No flanges. comes with a big yellow (.6bar) spring.
TRADED
Rare prof sheepdog blow off valve
Comes on a small section of 2.5" pipe, polished and in really good shape, prof logo is intact. Later version due to the flared trumpet.
175
AEM short ram intake. Came off my 97 EJ8, D16y8, may fit other applications. comes with K&N filter (need to be cleaned and re-oiled). Grey in color, still has CARB E.O. sticker.
90
P72 GSR tapped oil pan
Has 10-an fitting welded on for turbo drain line, however the fitting is all jacked up and does not work. No dents, just light scratches on bottom
50
GSR windage tray, new.
Has light surface rust from sitting but nothing a scotchbrite pad couldn't take off. never been in/on a motor
make offer (reasonable)
Compressor housings
Top housing, GT28R housing, came off s14 turbo.
Bottom housing, Fully Polished Garrett T3 60 Trim (only fits 60 trim t3's) .
GT28R - 125
T3 - 150
Nissan 60. trim t3 compressor housing
100
B series Blox type C cams
Have only 2000 miles on them, in mint condition. No cam gears
SOLD
Skunk2 test pipe
Previous owner welded up the o2 bung, not sure why (I guess if you're running a test pipe you don't need a rear of lol). It is barely used and super clean, no dents, cracks, etc. Not sure what that extra weld is for, it didn't crack and it wasn't modified.
85obo
AEM adjustable FPR
Red in color, anodizing is fading and the vacuum nipple broke off somehow, still in working condition if the nipple is replaced. Those are the only two issues, these are normally 135 from AEM so here's a chance to get one cheap. Nipple is easy to replace. If I can find another nipple I'll fix it and the price will go up. I can also have it re-anodized red or any custom color you want, obviously this is extra as well
85
DC Sports 4-2-1 Ceramic coated header, b-series
Came off of my ls-vtec, no longer needed since Im getting my turbo setup done.
Has light surface rust from use, no dents in downpipe section, has small dent on one of the runners just off the head but its really really small. Will be broken down into 2 pieces for shipping purposes
185
Boomslang OBD1 to OBD2B conversion harness
SOLD
Stock GSR intake elbow
In perfect condition, just a little dusty
25
B16 Cams
Have 50,000 miles aprox. Came out of my 99 Si. Have 2 sets with cam gears
100 each
Stock map sensor
I have an extra stock map sensor I don't need. In mint condition and perfect working order
$20
AEM b series fuel rail
Rail came on my ls/VTEC... started off as a blue rail, not sure how or why the anodizing came off but it's still a good looking rail. Rail is lightly polished, just enough to give the overall surface a little glow/sheen, the edges seemed to polish a bit more which really makes them pop compared to the overall rail. Comes with the rail end plug fitting for using a stock location fpr. Has holes on top of the rail for stock/stock replacement fpr and a pressure gauge. You'll need a plug for the gauge port if you don't use one. Rail has one or two rub marks (seen in pictures) but nothing large or detrimental to performance and actually when the rail is on the ,motor you don't really notice. Still has the lettering on the front of the rail. In near perfect condition other than the few rub marks
Here you can see the blue anodizing, you won't see it with fittings installed
Rub marks
And here you can see how the edges are polished
$100
125obo
TRADED
175
90
50
Compressor housings
GT28R - 125
T3 - 150
100
SOLD
Skunk2 test pipe
85obo
AEM adjustable FPR
85
185
SOLD
25
B16 Cams
100 each
Stock map sensor
$20
Rub marks
$100
Who is Mr Robot?
Ok i need to be evermore specific on trades... What i want is listed up there... Don't have it don't pm me.
I DO NOT need stock parts, much less stock audio equipment, din pockets, interior stuff etc.
WHAT I WANT
Not stock ls/vtec stuff... I have a b16 head
Aftermarket b16 springs and retainers
B16 edelbrock victor x intake manifold
Ls forged pistons and forged low compression 81mm pistons
2Dr ek carbon fiber interior parts
Unless you have something totally awesome please don't pm me if its not on the list.
WHAT I WANT
Who is Mr Robot?
Bump.. Make offers and trades. Want this stuff gone so i can free up some space
i noticed theres no carb oe label, but does dc header come with a carb legal sticker? you plan on cutting it into two if shipped?
Who is Mr Robot?
Its a two piece header. It unbolts..
No carb e.o. Sticker. None of the dc manifolds i've ever owned have had one
Who is Mr Robot?
Benen bars traded... bump
make offers or trades.. please?
Who is Mr Robot?
Bump
Added some parts (more coming)
Lowered some prices
Added better photos
Please help me, I was I'm a bad car accident and cannot work, I need to sell this stuff to cover medical expenses.
PLEASE MAKE OFFERS
Lowered some prices
Added better photos
PLEASE MAKE OFFERS
Who is Mr Robot?
Bump
PLEASE MAKE OFFERS, I MUST COVER MY MEDICAL EXPENSES
Who is Mr Robot?
No obd1 stuff
And I don't live in Louisiana.
The map sensor either came off my y8 or my ls/vtec, can't remember.., however they are all the same... same part number, scaling, etc, let me check shipping prcpices
Who is Mr Robot?
Bump
Had a house fire and I need to sell this stuff to cover bills and to have money to eat
Help a long time member out, all reasonable offers will be considered
blackeg
Northeast (Sales)
Dec 12, 2007 03:14 PM
GARAGE SALE ========= ek/dc stuff. mounts, covers, pulleys, swaybars, seats, intakes, throttle bodie
portfl0w
Dec 11, 2007 12:09 PM
