ECU swap, now electrical issues.
Old Jul 2, 2012 | 11:42 AM
EricRyan's Avatar
Default ECU swap, now electrical issues.
A few weeks ago, I swapped out my burned up ECU (P06-A02) with a used one, a P06-A01. Sure, it fixed my main problem and is driveable again, but now my dome light and trunk light do not work and aren't getting any voltage at either.
Today, I replaced my A/C high pressure hose. I went to put R134A in only to realize that my compressor is kicking on, but the fan isn't. This is making it impossible to accurately fill the refrigerant. I know my fan worked just last month and I find it hard to believe that it doesn't have something to do with my ECU swap since other electronic stuff has stopped working since then.
So what gives? I thought the A00, A01, and A02 ECUs were all interchangeable?
Old Jul 2, 2012 | 03:15 PM
Former User's Avatar
Default Re: ECU swap, now electrical issues.
...my compressor is kicking on, but the fan isn't. This is making it impossible to accurately fill the refrigerant.
These^ have NOTHING to do with the ECU and therefore are separate problems. Where did you test for for voltage? Give details if you want help fixing these problems.
Jared95
Honda Civic (2001 - 2005)
May 2, 2017 05:50 AM
ella94
Mar 7, 2006 05:24 PM
