94 del sol power issue. fuse box?
Old Jul 1, 2012 | 07:22 PM
94_DC's Avatar
Default 94 del sol power issue. fuse box?
Car had a issue with solid cel with key on we grabbed the fuse box kind of moved the plugs for the under hood fuse box and it primed and cel went away. Turned off car and when we went to re turn it on it just made like a click noise and now no power at all nothing. Moved wiring and nothing. Tested power to under hood box and have power as soon as key is on power goies away. battery is full and checked fuses. Is there something im missing or is the fuse box bad and shorting out now.
Old Jul 1, 2012 | 08:24 PM
Former User's Avatar
Default Re: 94 del sol power issue. fuse box?
The hood fuse box gets voltage directly from the battery. Check the connection.
And where are you probing when voltage is lost?
Old Jul 1, 2012 | 10:29 PM
94_DC's Avatar
i probed the wire that comes directly from the battery on the bolt. I probed the big fusable links basically everything with power. But when you turn key to the on position there is no power at that time. Check the ignition and same. But if i leave it on the first click of key power is not lost but still no dash or warning lights or anything. The hazards, lights, horn you name it dont have power at anytime key in or not. I probed both sides of the fusable links as well to make sure no broke links.
Old Jul 1, 2012 | 10:34 PM
Lou845's Avatar
id like to know as well, im having the same exact issue with my 98 civic. if i find out info ill be sure to let you know
Old Jul 2, 2012 | 10:58 AM
delsolintegra's Avatar
There may be a bundle of wires that are screwed to the thermostat housing location that are the ground connection for the ECU and effect a lot of systems. Make sure that is a clean connection.
Old Jul 2, 2012 | 02:09 PM
94_DC's Avatar
checked and cleaned didnt seem bad or dirt connections there but did wire brush just in case. Nothing on fuse box looks burnt or frayed ran out of things to look into.
Old Jul 2, 2012 | 03:26 PM
94_DC's Avatar
fixed it! bad grounding bolt for battery.
StevenEJ8
Feb 10, 2021 11:12 PM
95SE
Audio / Security / Video
Jun 9, 2011 03:31 PM
1993gsrcivic
Apr 10, 2009 11:14 AM
