turn signals
Old Jul 1, 2012 | 01:37 PM
fredefhatch's Avatar
Default turn signals
well about a month ago i changed my windshield wiper switch so my car could have the intermidiate setting i also changed the smaller fuse box labled B, the intermidiate setting worked only randomly and now it doesn't work at all, around the same time my turn signals started working randomly to i assumed it was the smaller fuse box so i switched it back and the box labled B smelled burnt switching out the fuse box to the old one did not make the turn signals work, i switched out the fuse also, so i am guessing it is the relay, now my question is does anyone know which relay is for the turn signals? btw my car a 1991 civic hatchback base model
Old Jul 1, 2012 | 02:49 PM
CRXcaliber's Avatar
Default Re: turn signals
This is for a CRX but it should be the same. If not, let me know and I'll see what I can do...
Old Jul 2, 2012 | 09:26 AM
thanks for the diagram found it and fixed
Old Jul 3, 2012 | 12:07 PM
CRXcaliber's Avatar
No problem. Glad to help!
Posted from Honda-tech.com App for Android
Old Jul 31, 2012 | 08:20 PM
Sailboat's Avatar
not entirely the same. Got a 91 Hatch, small wire tuck that's unfinished. Hazard light indicator works, rear lights flash, but front are not hooked up yet. I try to use the turn signal, but no dash indicator light comes on, any suggestions?\
would not having the front indicator lights wired yet cause this?
would not having the front corner lights short this out?
Old Aug 1, 2012 | 07:09 AM
well for my problem it was the relay switch, well it maybe the turn signal switch that's bad or simply the fact that they are not connected yet
tallguy21
May 17, 2012 04:13 PM
gnxpro24
Feb 2, 2011 03:52 PM
efcivic317
Dec 2, 2010 02:25 PM
RapeV-8
Apr 15, 2003 10:26 PM
