93 Civic - NO START but has spark and fuel
Old Jun 30, 2012 | 11:53 PM
GarageNut's Avatar
Default 93 Civic - NO START but has spark and fuel
Hey guys. New account here. Can't remember my old account.
Anyways so I have a 93 civic 1.6 here
Car was running fine and up and died ive been told. Bear with me here. Has spark and fuel with good compression
-So ive done a fuel pressure check at the rail and filter. Around 55psi.
-Injectors 12volts
-Ignition coil showing 12volts
-Spark plugs 12volts
-Compression 150psi on all 4cyl
So what the heck is going on. Car cranks but won't start. I know main relay is a big problem with these cars but it is getting fuel. Any ideas?? Have the car in my garage and have it set to be finished today (sunday) Ohh and yes I did do a search for this. THANKS GUYS
Old Jul 1, 2012 | 01:25 AM
Fnix's Avatar
Default Re: Another NO START problem
I had the same problem, it was my battery :\
Old Jul 1, 2012 | 08:58 AM
GarageNut's Avatar
bump
Old Jul 1, 2012 | 09:46 AM
Former User's Avatar
CEL codes?
Spark should be bright white at all four plugs. Is it?
Have you checked the mechanical timing or compression tested the cylinders?
Old Jul 1, 2012 | 10:04 AM
GarageNut's Avatar
Originally Posted by RonJ@HT
CEL codes?
No cell codes. Tested cylinder compression. Don't remember spark color.
Timing will be checked today. Know it doesn't have a broken belt but maybe some jumped teeth.
Old Jul 1, 2012 | 10:16 AM
Weak spark -- yellow, orange, or deep blue -- can prevent spark.
bgamera
Aug 14, 2014 12:20 AM
Cav3man
Mar 24, 2012 03:44 PM
ORguy
10
Mar 22, 2011 05:25 PM
Hangmen
Oct 8, 2006 11:16 AM
knomexx
Jul 14, 2005 08:13 AM
