93 Civic SI intermittent start issue
Old Jun 30, 2012 | 09:50 PM
JUICE66's Avatar
Icon2 93 Civic SI intermittent start issue
Bone stock 93 si recent starting issue-
Sometimes starts fine, usually it wont crank - like its a weak battery, but battery tests fine, can start via popping the clutch/jumper cables, alternator tests fine, main engine relay/s fine, no CEL's when jumped ecu harness
After i pop the clutch to start when i go to start up 1 out of 5 times it will start right up.
Help!
Old Jun 30, 2012 | 09:58 PM
Former User's Avatar
Default Re: 93 Civic SI intermittent start issue
If jumper cables allow the starter to crank, then the battery is weak. What's the voltage across the battery posts?
Old Jun 30, 2012 | 10:23 PM
JUICE66's Avatar
Originally Posted by RonJ@HT
If jumper cables allow the starter crank, then the battery is weak. What's the voltage across the battery posts?
12.73
Old Jun 30, 2012 | 10:39 PM
Have you cleaned and tightened the battery connectors, the G1 battery ground attached to the chassis, and the G3 transmission ground?
Old Jun 30, 2012 | 11:06 PM
JUICE66's Avatar
yes, yes and yes & g1 & g3 make good ground
Old Jun 30, 2012 | 11:08 PM
When the starter won't crank, does the starter solenoid fail to receive battery voltage? If so, check the safety switch and rubber stopper it presses on at the top of the clutch pedal, as well as the ignition switch.
Old Jun 30, 2012 | 11:26 PM
JUICE66's Avatar
Not sure, the times i've tried to replicate the problem with my meter nearby i cant get it to happen. grrrr Carrying the meter around in the car till then. But I have checked the switch and rubber stopper - both ok.
It's not so much that it wont crank, when it happens its just a weak half crank
I appreciate the help, ill check the ignition switch tomorrow and post results.
Thanks again
Old Jun 30, 2012 | 11:31 PM
JUICE66's Avatar
i can jumper from the battery to the ignition switch wire connection on the solenoid - if it works, it's not the solenoid, and its either the ignition switch or the clutch pedal switch. edit: or wire broken/loose somewhere
right?
Old Jul 1, 2012 | 07:17 AM
Here's the circuit, which involves a relay, so the problem also could be several different wires or the relay.
Old Jul 2, 2012 | 01:50 AM
JUICE66's Avatar
where is the "starter cut relay" located? under leftside of dash?
Old Jul 2, 2012 | 06:15 AM
NiKKa NiKKy
Jun 30, 2022 09:59 PM
jorge59la
Sep 27, 2007 07:24 PM
Bruce Banner
Apr 12, 2007 12:49 PM
93civichatchinky
Apr 10, 2007 03:11 PM
ricedoutb16
Oct 27, 2006 12:20 AM
