OBD0 TO OBD1 CHECKING CHECK ENGINE LIGHT
Old Jun 29, 2012 | 10:45 PM
Jdmefsir12's Avatar
Default OBD0 TO OBD1 CHECKING CHECK ENGINE LIGHT
HEY HOW U DOING I HAVE A EF SEDAN I NEED TO CHECK OUT WAT MY CODE IS ON MY CHECK ENGINE LIGHT IS.. I HAVE OBD0 TO OBD1 JUMPER HARNESS DONT REMBER HOW TO RETRIVE THE CODES.. ANY HELP THANKS
Old Jun 30, 2012 | 12:22 AM
93delsold16z6's Avatar
Default Re: OBD0 TO OBD1 CHECKING CHECK ENGINE LIGHT
Obd0 has codes directly on ECU.
Obd1 needs the service connector to be jumped. It is located in passenger foot well. it looks like a sensor that is loose. take a paperclip or wire and connect both open ends together.
once that is done, turn key on to IGNITION ON only. no need to start car. CEL lamp will blink. count the blinks. record them.
Im sure you know how to find out what blinks mean what. And also can find your way to see what numbers mean what.
Old Jun 30, 2012 | 01:41 AM
Jdmefsir12's Avatar
i know to find the codes and see wat the problem is but i was trying to figure out wat wire it is that i ground ir ember in my old ef it was a yellow wire... but not sure about this one..
Old Jul 1, 2012 | 08:26 AM
I just told you where it was . I think the color is gray btw. damn
Old Jul 1, 2012 | 02:39 PM
crx_si-r's Avatar
Before you go off on people read what is posted. The OP has an ecu jumper, which means the scs (service check signal) wire is most likely left loose and just need to be grounded.
OP, you can find this wire on D4.
On my ecu jumpers I wire them up so you can still use the stock service connector.
Wire colors for D4 vary on who makes the jumper. Just ground the wire and your Check engine light will flash your code
Old Jul 1, 2012 | 08:13 PM
Jdmefsir12's Avatar
well thanks bro.... yes i drive a ef sedan..... and its obd0 with obd1 jumper harness.... so yes i rember on my old one it was a yellow sinlge wire that needed to be grounded....
existanzcivicb20
20
May 22, 2017 04:23 PM
suburban_ninja
Oct 31, 2013 11:21 AM
akurtzer57
Engine Management and Tuning
Aug 2, 2010 01:20 PM
cor4ey
Dec 20, 2008 12:42 PM
turborex2
Jul 22, 2005 07:13 AM
