RHD Window Wiper Help (92 EG6)
Hey guys, I finally got around to buying a rhd wiper set-up for my car and I'm having trouble hooking it up because I can't find the connector on my end to hook into the wiper assembly. My car has a shaved bay, so wipers were never used. Provided my wire harness does not have the connector needed for the wipers, what can I do in terms of custom wiring to make this work? Sorry if I sound vague guys. Here are some pics of the connector on the wiper too. The pics are close enough where you can distinguish the color of the wires as well.
its hard to tell in the pic but it looks like there is a black wire that would be the ground andthe other wires are diff colors if u play with the wires using a jumper those wires may be for the other speeds so if u get a toggle with multiple on positions like http://www.google.com/products/catal...ed=0CG0Q8wIwAg then u only need one toggle and u couldhave multiple speeds
wire electrical tapsoldering iron not needed but always recomend soldering and a place to mount the switch find a good metal ground connect live power to the toggle first then use the switched terminals to run to the wiper plug
Okay, so basically, get some wire and have it soldered onto the existing blue and blue/yellow wires. Connect those two wires to the toggle switch. And then connect a wire from the switch to a terminal in my fuse area and use a 15a fuse etc to power it? And this is a question for if I buy the switch you posted.
yea or any switch that has to perminent on positions cause some are constant and some autamatically return to off when u let the switch go u could also tap into an accesory pin they are the little male connectors on the fuse panel
rhdins
Oct 19, 2012 02:38 PM
HondaGuy951
Jan 17, 2011 08:30 AM
