98 Gsr Died
Old Jun 28, 2012 | 09:26 PM
98_ssbp's Avatar
Icon3 98 Gsr Died
I took apart under my dashboard to try and find a bad ground on my head unit. Found and fixed that issue. I noticed one of the wires going to the ignition was stripped. I forgot to wrap it with some electrical tape and reassembled everything. I started my car and it started just fine. I had the steering wheel the whole way up to get under the dash. So I released the tilt lever and the steering column fell down to the lowest setting. As this happened, my car shut off.
My cluster lights no longer work. When I go to start it, it does not even attempt to turn over, and I don't hear either the main relay click or the fuel pump prime. When I turn the care to ACC, it does nothing and everything is still unlit. The only things that work are my dome light, and headlights.
I am lost at what I did, but I do believe I shorted something out with the ignition wire being unprotected and touching metal when I lowered the steering column. Any info on where I should start is much appreciated
Cliffs:
took apart car
saw unprotected wire
forgot about it
steering column falls
car dies
Old Jun 28, 2012 | 11:38 PM
turbohatch96y7's Avatar
Default Re: 98 Gsr Died
did you check the battery fuse in the under hood fuse box??
Maybe you cut the cable as you lowered your steering column?
Old Jun 29, 2012 | 01:21 AM
shdw06's Avatar
re-check your fuses and fix that wire!! it happens
wakaba_db1
Jan 13, 2013 02:23 PM
98_ssbp
Jul 8, 2012 06:00 PM
fausz
Mar 8, 2005 11:37 AM
c8r9x
Apr 23, 2004 08:10 PM
