Default D16y7 to d16z6 using stock engine wiring harness
Old Jun 27, 2012 | 09:33 AM
cabot974's Avatar
Default Default D16y7 to d16z6 using stock engine wiring harness
Hi, all
I swapped my d16y7 out of my 98 civic non-vtec. i swapped a d16z6 vtec engine and i still only have the d16y7 harness and P28 ecu with a harness converter.
I added some wires for the vtec pressure switch and vtec solenoid.
the engine starts normally but when I start to accelerate,
the engine is not performing too, the others symtomps are:
It's very hard to start the car, engine will stumble upon acceleration too and I have a CEL code 9( crank angle sensor fault).
I use all d16z6 sensors ( dizzy, injectors, throttle body, IACV...)
can you help me please?
Old Jun 28, 2012 | 05:29 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: Default D16y7 to d16z6 using stock engine wiring harness
How did You wire up the distributor to make it work
Old Jun 28, 2012 | 09:12 AM
cabot974's Avatar
I cut D16Y7 dizzy's plug and I welded it on d16z6 dizzy.
Old Jun 28, 2012 | 11:29 AM
cabot974's Avatar
I have use this wiring
http://img.photobucket.com/albums/v4...stributors.jpg
h23vtec_dc2
Oct 1, 2014 07:15 PM
wht_eg
Jul 3, 2008 12:04 PM
Vp Special K
Aug 16, 2004 06:11 AM
Tyreece04
May 10, 2004 04:38 PM
