EM1/Jdm itr - cranks when it wants to?
I just finished swapping a jdm itr into my em1 and it seems To start when it wants to. Battery checked good, only thing I can think is a bad starter or bad ground. Car doesnt even crank , does nothing when I try to start it. tapping the starter doesnt do the trick either. I also install some solid aluminum race mount so maybe im not getting good ground? I currrently have a ground from tranny to frame and vc to chassis.
Yes push start and double clutch starts the car, how I know because some nice people helped me get going.
Yes I can hear the fuel pump prime when I turn on the ignition.
Sometimes jump starting it will start it up rigjt away but seems like its geting worse
If your starter feels like it's getting stuck. Check the wires that go into the fuse box, my wires keep corroding in the fuse box on my K swap. I think the starter requires more power than b/d series engines.
Problem Fixed, thanks for all the help!!!!
Car wasnt getting enough ground, maybe from the aluminum mounts so I test with another ground from engine to chassis and it fired right up everytime.
