high compression daily driver?
i have a b18c engine .with a stock bottom block and iam also getting my head decked
i want to do a high compression all motor what kind of valves should i get /retainers/ springs?
im also getting my head ported with a 3 angle valve job and also i will be running blox stage 2 cams also what kind of manifold should i run because i currently have a blox 68mm on my car.
what would you guys recommend
I think the flat valves give you like .2 bump in compression it's really not much you can run those with supertech valve train and a eldelbrock manifold an a good header but unless you up the pistons your really not gunna be high in comp. what car is this gunna be in? An R? You will need a serious bump in comp to go 13's and with a compression over 12.5 I think you need to run e85 or race gas bc of detonation of lower grade fuel. And I don't know bout Cali but a gallon of race gas is stupid expensive here in ct do not to ideal for a daily driver
What car would this be in? If you did ctr pistons it would def help. In a eg hatch with good tires and a good launch I'm sure you could break into 13's with a good tune
13's no problem in an EG with a healthy ITR motor. You don't need to run high compression for that at all. Now low 13's are a different goal. But again on 91 octane don't push your luck.
Believe it or not there are people that daily drive on race gas mixed with 93 octane. I know 2.
ekcoupeh22 is one of them. lol
You're dealing with engine internals, no room for knock off parts. Buy the real deal stuff and never have to worry about it.
You can run any thing as a DD it all depends on your right foot. I have a Turbo R for 3 years now, no issues. On the other hand people build motors and blow them up in 3 weeks bc they cant keep the pedal off of the floor.
13's is a very very very easy mark to make. But think about your horse power wants/needs, rather then your 1/4 mile time.
user 98292739
Sep 22, 2006 06:19 PM
Full Race A6
23
Jul 28, 2004 04:18 AM
PirateMcFred
Jun 17, 2004 09:23 PM
