Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
1989 ef track car
Old Jun 26, 2012 | 09:27 AM
Gibby 123's Avatar
Default 1989 ef track car
Just wondering if anyone can share there suspension set ups. I currently run an 89 ef hatch track only. B16 stock with lsd trans. car weighs 2081 full of fuel with me in it. i have corner weighted till the cows come home and have a differance of 36lbs between rears and 96 between fronts. i am fairly happy with that , however stock front bar and 450lbs front springs and 225lbs rear springs with a 25mm rear bar made for a really "leany over" set ,had that set up for 4 years and drove the same car with 450 frt and 600rears and wow way better! so i had a set of 450 rears to try and wow Way better. Just wonder if a big bar in the front would be better as well? i am just barely now lifting rear inside wheels where as the same set up car with the 600 rears lifts wheels all the time, not sure if I am still to soft on the rates?
any feed back is great
Old Jun 28, 2012 | 09:43 AM
Gibby 123's Avatar
Default Re: 1989 ef track car
No one??
Old Jun 28, 2012 | 12:58 PM
Shinny's Avatar
You waited 20 minutes? Have you done any searching of the forum? The advanced search option with some filters on will do wonders. But in general a stiffer sway bar will counter body roll. Which is what it sounds like you're having trouble with.
Old Jun 28, 2012 | 01:15 PM
Robin6's Avatar
read both post dates.
Old Jun 28, 2012 | 05:48 PM
Shinny's Avatar
Lol my bad, was on my phone.
Old Jun 28, 2012 | 09:51 PM
sanimalp's Avatar
$cat /dev/urandom
My set up on a 91 CRX is: no front lower bar, ASR 24mm rear sway bar w/ brace, 550 front springs and 330 rear springs. The front and rear ride height are set very similar on my car, and I find it handles really neutral. if anything, it tends toward oversteer with Z214 slicks. A lot of people run higher rates in back than in front, but i don't. I am still learning though, so i might switch the spring rates out next year, front to rear, and see how that does.
Old Jun 28, 2012 | 10:26 PM
turtleef's Avatar
All stock arms!!! Again all stock just new bushings Hondas with sir rear n front sway bar n type r style rear lower control arms dropped on koni yellows with skunk 2 coils front 600kg n 800kg in the rear powered by stock B16 on set ls-mesh rims with falkens I don't loose my tail for sh** n slips throo corners lik a dream at high speed bouncy as he** on street tho! I'm working on a set of potenzas tho they are beast rims
tonylovesjdmEF9
22
Dec 24, 2011 07:55 AM
kyleb18t
Suspension & Brakes
13
Jan 25, 2009 02:43 AM
E-AT_me
Jul 7, 2007 10:07 AM
Tippyman
Suspension & Brakes
13
Nov 10, 2006 08:46 PM
