tranny seal leak on a gsr transmission
Old Jun 26, 2012 | 08:00 AM
gokus-eg2's Avatar
Default tranny seal leak on a gsr transmission
i have a gsr tranny on my del sol that been leaking from the passenger side, i already replace the seal numorous times, i know how to do it (seal flush with the tranny)ive used honda seals and cheapo seals and it still leaks...i did pop an axle out one time while going about 85mph n replaced the axle right after...could i have effd up something inside the tranny or what other possibilities are there?theres no cracks on there
Old Jun 26, 2012 | 08:10 AM
kyden's Avatar
Default Re: tranny seal leak on a gsr transmission
check your diff for play.
Old Jun 26, 2012 | 08:16 AM
instructor74's Avatar
Seal leak for several reasons. Either its the wrong one for your Trans, its been damaged during install to the Trans or upon drive shaft install, or there is play in the diff bearings causing play in the shaft and damaging the seal
fcm's Avatar
fcm
Old Fart
Is it actually leaking past the seal?
If so, I would check the axel, as it is was replaced, [what axel is it, make]?94
Old Jun 26, 2012 | 03:01 PM
gokus-eg2's Avatar
what's the best way to check the differential?
Old Jun 26, 2012 | 03:45 PM
gokus-eg2's Avatar
the axle was bought brand new from autozone, its an oem like one...ive never had problems with these....is there sposed to be any play when its in place nd car is jacked up in the air?
Old Jun 26, 2012 | 03:47 PM
gokus-eg2's Avatar
ive changed that seal about three times....the time is used the oem honda one it only leaked a little, when i changed it and used one from an autostore it started leaking way more
Old Jun 26, 2012 | 09:12 PM
fcm's Avatar
fcm
Old Fart
It would not be the first time that an "oem like one" or even an OEM Honda part was DOA.
But I agree with instructor74 and you, you did "pop" and axle doing 85, that can't be good for the differential.
Did you check the bearing before installing the new drive shaft and seal(s)??
Don't forget to check the driveshaft. 94
Old Jun 26, 2012 | 10:22 PM
gokus-eg2's Avatar
i did but i woud have never known how to tell from a good one or damaged one as ive never had to deal with nor do i know exactly how the tranny works.i dont know exactly what the differential does but the car runs normal and straigt on acceleration..sounds normal,only thing u can hear is the throw out bearing...but the only problem i see is the leakage....
Ricey McRicerton
14
Nov 19, 2008 05:17 PM
lilpastrana
Oct 19, 2007 07:03 PM
civicjoe8
Apr 11, 2006 08:52 PM
pnltnc
Dec 7, 2004 01:51 PM
Chrislow
Nov 8, 2002 11:07 AM
