Transmission & Drivetrain Gearboxes, Differentials, Clutches
M2Y4 Countershaft Top Needle Bearing - Orientation
Old Jun 25, 2012 | 04:07 PM
dre2day's Avatar
Icon6 M2Y4 Countershaft Top Needle Bearing - Orientation
Guys, I was wondering if you could help me with a bearing question.
I am assembling the countershaft and the needle bearing right under the top ball bearing.
In the service manual it looks like the metal around the bearings sit where it can slide upwards, as pictured in the attached pictures. Hope that makes sense.
But I have a weird noise in the trans that sounds like metal rubbing while driving and at higher speeds its a little louder.
Anyways I was wondering if the words on the bearing need to face upwards like all the other bearings.
Old Jun 25, 2012 | 05:56 PM
94EG8's Avatar
Seagull Management
Default Re: M2Y4 Countershaft Top Needle Bearing - Orientation
The closed end of the outer race goes up.
Old Jun 25, 2012 | 08:00 PM
dre2day's Avatar
To be clear. You're saying that the outer part shouldn't be able to touch the 5th gear?
Old Jun 26, 2012 | 05:06 AM
94EG8's Avatar
Seagull Management
Correct.
parahelium
Jun 8, 2017 10:46 AM
Hellahflush
Mar 27, 2015 05:15 PM
canadaek
Nov 6, 2012 02:05 PM
petergriffen
Feb 25, 2007 05:15 PM
