slight miss fire when first starting car
Old Jun 25, 2012 | 02:24 PM
...:::MaRk:::...'s Avatar
Default slight miss fire when first starting car
How's it going I have a little problem with my daily driver which has been giving me a headache as to what the problem could be.. Im gonna try to explain it the best way I could..
A little run down of the car is that its a 1995 civic with a 2000 ex long block with original 95 ex trans.. the motor is basically stock I have never had a CEL no knocking, overheating,smoking nothing at all.. The car is running on a stock P28 has a 255 fuel pump and straight pipe to a stock muffler..
My problem is recently the car when i start it sometimes it has a slight missfire for about 2 sec then it clears up and idles normal.. I thought it was my spark plugs so i changed them and made sure the new ones were properly gap'ed and they are I thought the problem would be fixed.. It wasn't so then a friend of mine said that it could be the IAC.. so we then took the IAC off and cleaned it non the less the IAC was disgustingly dirty I thought that would fix the problem but it didnt..If it means anything my car does have a system in it so im thinking maybe the battery could be going since my lights tend to dim but i dont think that would cause a missfire..My car only gets sunoco 93 and oil is only changed with royal purple on time.. Im at a lost at what it could be i just want to fix the problem and continue dailying the car lol.. any input would be great.. thanxz h-t
Old Jun 25, 2012 | 02:38 PM
CreamCivic's Avatar
Default Re: slight miss fire when first starting car
Have you tried checking the actual spark from the distributor?
Old Jun 25, 2012 | 02:40 PM
K20 junkie's Avatar
Yea just Change cap rotor pluugs an wire basically a tune up. Ur misfire
Should go away
Old Jun 25, 2012 | 02:47 PM
Pleiadi79's Avatar
are u sure of ur timing at idle?
Old Jun 25, 2012 | 02:59 PM
Not yet but a friend of mine did tell me that it could be something with the distributor.. but i changed my distributor about eh lil less than a year ago so i figured it was good lol it still "looks" fresh lol
Should go away
Thanxz im actually going to do that i dont recall ever doing a tune up to the car..
my timing is perfect i never really had a issue with this motor
Old Jun 25, 2012 | 03:10 PM
CreamCivic's Avatar
i was just saying because I had the same problem I replaced the fuel pump to walbros 255 nd put fresh spark plugs after all that same thing, then realized my distributor was the problem.
Old Jun 25, 2012 | 03:23 PM
Pleiadi79's Avatar
if your timing is perfect should be something on the distributor, did u check plug's wires are u running stock ones?
Old Jun 25, 2012 | 03:47 PM
motegicivic's Avatar
You could test the coil and icm in the dizzy those are the 2 main components.
Old Jun 25, 2012 | 09:21 PM
jbpnoman's Avatar
A few things before you go off buying random parts and possibly wasting money. What color spark are you getting from the plugs when grounded to the frame? It should be bright white/blue. Do you think your timing is perfect, or did you actually check the marks on the cam sprocket and crank? Did you borrow/rent/buy a timing light to check the ignition timing?
Also, do a fuel pressure test. There are write-ups all over these forums - just search. You can borrow/rent/buy the tool from your local parts shop.
As far as the tertiary and probably unrelated things, if you have a "system" in your car and your headlights are dimming, don't half-*** the job. Call up Ohio Generator and get a proper alternator for your car stereo. No, a 5 Farad capacitor isn't the correct way to fix it. Finally, do your wallet a favor and stop wasting money on Royal Purple. It's nothing but bling factor, and you can get the exact same oil in a different colored bottle for half the price.
Old Jun 26, 2012 | 01:35 AM
Pleiadi79's Avatar
I suggest to follow all these directions....
Old Jun 27, 2012 | 09:26 AM
gsrjdmej2's Avatar
might have a bad valve in that cylinder have you checked compression?
Old Jul 6, 2012 | 06:31 PM
changed cap n rotor plugs and wires..tried fuel injector cleaner still doing the same thing..cleaned iac too im at a lost as to what it could be...
Old Jul 6, 2012 | 06:32 PM
Former User's Avatar
CEL codes? Does the CEL work?
Old Jul 6, 2012 | 06:34 PM
cel works fine.. not showing any codes at all..
Old Jul 6, 2012 | 06:35 PM
cel works fine
How do you know?
Old Jul 6, 2012 | 06:39 PM
How do you know?
it turns on when i turn the key right before i start it.. it comes on then goes off. when the car previously had a problem the cel came on so it works fine.. jumping the harness it show's the code when i had the previous problem
Old Jul 6, 2012 | 06:44 PM
What code is showing? After you reset the ECU, does the same code return?
Old Jul 6, 2012 | 06:46 PM
I was talking about before when it had a problem.. was giving more of a answer to the question you asked "How do i know my cel is working" but the car has no cel now..
Old Jul 6, 2012 | 06:48 PM
Do you have a low cold idle speed rather than an engine misfire? Do you have an FITV? If so, have you cleaned and adjusted it?
Old Jul 6, 2012 | 07:00 PM
what do you mean? im gonna google what fitv is..but my idle is steady alittle under 1k id say 8 or 900
Old Jul 6, 2012 | 07:04 PM
Click FITV in my signature.
What is the idle speed when the engine is cold (when you are having the "misfire" problem)?
Old Jul 6, 2012 | 07:07 PM
didnt even see that in your signature thanxz..idle is alil over 1000.. but it doesn't always do it at cold starts..
Old Jul 6, 2012 | 07:21 PM
...but it doesn't always do it at cold starts..
Why do you have an aftermarket fuel pump installed? Why are you using 93 octane fuel?
Do you have a stock 00 D16Y8 engine?
Is your P28 ECU chipped?
What brand plugs, wires, cap, and rotor are installed?
Is the ignition timing set to spec?
Have you had the alternator tested? If not, measure voltage across the battery posts when the warm engine is idling under no electrical load and under high electrical load (high beams, blower on high, defogger on).
Old Jul 6, 2012 | 07:40 PM
when i had a problem my fuel pump wasn't coming on so i thought that it went so i replaced that with a 255 pump when it was actually the ecu..
was always told that 93 is best for the car.. helps it run quieter and its cleaner supposedly..i always use 93 in all my cars swap or not..
yes completely stock down to the intake and mounts lol
nope no chipped ecu bone stock p28
cap and rotor are from the honda dealer..wires and plugs are from autozone..not too sure what brand the wires are but the plugs are NGK cant remember the name of them but they are the cheapest ones not the expensive ones that tend to go within 500 miles
yes when the swap was done it was set to stock spec..
nope i haven't tested it yet but i will.. i have a feeling that my battery is going but everyone says its something with the ignition i feel like im replacing parts that have no problems..
Old Jul 6, 2012 | 07:53 PM
Your fuel pressure is too high. Remove the Walbro pump and re-install the stock fuel pump.
It's a myth. You're wasting money and potentially hurting the engine. Use only regular 87 octane fuel.
I don't believe a P28 is the correct ECU for your engine. Somebody please correct me if I'm wrong. The stock 00 D16Y8 has the FIA system. Is it installed?
You should be using NGK ZFR5F-11 plugs. Are they properly gapped?
Good
What voltage do you measure across the battery posts with the engine and key off?
Gawdzila
Apr 2, 2016 09:52 AM
rdelucas1
Jul 25, 2008 02:13 PM
nathanjohnson2009
May 15, 2008 12:20 PM
