B16a2 engine in EG - need help with set up of coolant hoses
Old Jun 25, 2012 | 01:54 PM
Pleiadi79's Avatar
Icon6 B16a2 engine in EG - need help with set up of coolant hoses
Hi guys does anyone have an idea and pictures on how to setup all water hoses on b series, for a race car?
I mean what to do with the water line coming out fro int manifold for example and with the hoses starting from termostat....
any ideas, help would be appreciated!
thanks
Old Jun 25, 2012 | 01:56 PM
grumblemarc's Avatar
The Grumpiest
Default Re: water circuit setup
For a racecar? How is that any different than a regular car?
maybe you might want to look around the Drag Racing forum.
Old Jun 25, 2012 | 02:00 PM
Former User's Avatar
Default Re: B-series engine - need help with set up of coolant hoses
What specific engine and car?
Old Jun 25, 2012 | 02:08 PM
Pleiadi79's Avatar
Eg with b16
Old Jun 25, 2012 | 02:13 PM
Originally Posted by Pleiadi79
Eg with b16
^Can you be more specific?
Old Jun 25, 2012 | 02:25 PM
Pleiadi79's Avatar
ok sorry, i have no ideas on what to to with the bypass intake manifold hose and with the two hoses for heater. since car is bare i think i dont need that hoses. i run a mgnus aluminum manifold whare is prepared the stock water hose nipple.
now i've connected all the hoses doing some kind of bypass but i'm not sure the water is flowing correctly, this why at aronud 150F the hoses are pressurized like at 200F. I'm 90% no air in the circuit but not sure on correct water flowing direction
Old Jun 25, 2012 | 09:17 PM
jbpnoman's Avatar
When he said be more specific, he meant be more specific about WHAT B16 you're using. 1G B16A, 2G B16A, B16B, B16A1-7. There are differences.
Old Jun 26, 2012 | 01:39 AM
Pleiadi79's Avatar
ok sorry Im quite sure its a b16a2 of '93
Old Jun 26, 2012 | 06:47 AM
Default Re: B16a2 engine in EG - need help with set up of coolant hoses
Old Jun 26, 2012 | 02:52 PM
Pleiadi79's Avatar
This is the setup i have in my car.
just would know what to do with the heater hoses coming from therm housing and side head, and also with water bypass from manifold to therm housing. i currently closed all of them since i no longer have heather and thermostat.
What do you guys think, would work properly?
thanks
Old Jun 26, 2012 | 05:20 PM
Are you saying you don't have either a thermostat or thermostat housing? If so, why?
Old Jun 27, 2012 | 02:25 AM
Pleiadi79's Avatar
I have the housing like the one in the picture i posted. i dont have only the thermostat inside the housing.
Its a race car i no longer have heater. What to to with the hoses that are originally connected to the thermostat housing and to the manifold. Thats all.
is ti ok to close them? wil post picture
Old Jun 27, 2012 | 03:06 AM
The Grumpiest
Is it my imagination or are you making this harder than it has to be? Just loop the lines at the engine; oulet to inlet. Or just cap them off. Anything at the firewall you can remove.
Old Jun 27, 2012 | 03:17 AM
Pleiadi79's Avatar
This is the answer i was expecting!
Old Jun 27, 2012 | 01:14 PM
Pleiadi79's Avatar
here the pict of what done..
what do u think?
Old Jun 27, 2012 | 01:48 PM
The Grumpiest
Is it working?
Old Jun 27, 2012 | 02:06 PM
Pleiadi79's Avatar
At the moment yes. hadnt time today to get it on working temp. with the old setup with hose looped i blow the headgasket so i suspect it happened due to wrong hose looping/ connection. That why of my question.
cubanteg16
Sep 3, 2009 10:38 PM
turbogenetic
Jun 1, 2009 12:20 PM
MikeMarkota
Mar 7, 2006 12:28 PM
crxb20ed
Jan 5, 2005 12:22 PM
HUBB
Apr 21, 2003 07:43 PM
