B16aY1 passenger side wheel locking up. possible axle issue
Old Jun 25, 2012 | 11:04 AM
BubbleBoy86's Avatar
Default B16aY1 passenger side wheel locking up. possible axle issue
EF 89 civic hatch B16aY1 passenger side wheel seems to lock up when slowly accelerating or turning right. when accelerating the wheel pulls left and when decelerating it pulls right. ive search and found that sometimes the axle is the wrong length. so im searching for a clearer answer.
Old Jun 25, 2012 | 12:19 PM
villc713's Avatar
Default Re: B16aY1 passenger side wheel locking up. possible axle issue
What axles are you using for your swap? Also what half shaft?
Old Jun 29, 2012 | 05:11 AM
91 integra axels
Old Jun 29, 2012 | 08:02 AM
93delsold16z6's Avatar
Torque steer is normal if halfshafts are of a diff length. I know on my DSM they are diff length, but the long one had a carrier bearing which bolted to the block to keep it as straight as possible and also to cut its length in half to help the steering issue.
Sticking wheel could also be stuck sliding pins also. check both and lube if needed. Could be that simple you never know
Old Jun 29, 2012 | 08:21 AM
villc713's Avatar
Have you checked to see if it were a brake issue like a calliper locking up or something?
Old Jun 29, 2012 | 11:18 AM
villc713's Avatar
Another I was just looking up bro did you remove the dust shield off the back of the spindle? Ima pm you something that may help you out.
BIGef
Jul 12, 2013 10:13 AM
dc5itracer
Oct 11, 2008 09:44 PM
truevietluv636
Sep 8, 2007 03:00 PM
ITRDC2R
Jun 1, 2007 05:43 AM
servion
Sep 5, 2003 11:33 AM
