EG SI GSR SWAP
I just put the motor in the car and was wondering if you have to do any wiring to the to make the gsr engine work. Its an OBD1 gsr going into 92 eg si. Any help would be appreciated. Also the car is using Hassport motor mounts will a stock B series T bracket work or does it need the one from Hassport because the T bracket is 1/2" to short for the bolt to go into the rear motor mount.
Thanks
Thanks
http://www.oemacuraparts.com/acura/b...st7-000-acura/
rice is nice
Jun 25, 2012 03:45 PM
