92 Accord Fast Idle Valve Question
Old Jun 25, 2012 | 03:41 AM
jkrueger2020's Avatar
Default 92 Accord Fast Idle Valve Question
Does anyone have any experience diagnosing a problem with the fast idle thermo valve?
My Haynes auto manual says that when the car is cold, if you push down on the plunger (can't recall exact term), you should hear air woosh out. It then says you should warm up the car so the fans kick on. At that point you should not hear any air when you push down on it. The Haynes manual says if you get air coming from it when warm, it's bad and needs to be replaced.
Well, I tested that this past weekend and even when the car was fully warm, I could hear air wooshing from it (even before pushing down on the plunger). So if the Haynes manual is right, the part needs to be replaced.
Can anyone confirm whether this is correct? I ran out of time to clean the part this weekend, so I plan to do that shortly, but am just wondering if anyone has experience with one of those going bad and if they could confirm whether the Haynes manual is correct that I actually need to replace the valve due to the sound of rushing air when the car is warm?
Thanks,
Jonathan
Old Jun 26, 2012 | 04:20 AM
KevinnC's Avatar
Default Re: 92 Accord Fast Idle Valve Question
My idle was bouncing going from 1000-2000 by it self, cleaned and screwed back down mine and it fixed it. Not sure if that'll help you out but good luck.
Old Jun 26, 2012 | 04:54 AM
jdmcertified909's Avatar
yeah screw it down counter clockwise. if it still does it the seals inside are shot and need to be replace.
Colors201
Honda CR-V & Element
Aug 13, 2019 07:50 AM
Nicholas Mudd
Sep 29, 2015 09:00 PM
93_civic_hatch
Jun 26, 2008 12:47 PM
90_civic_Si
Nov 23, 2006 12:27 PM
fe519
Nov 8, 2004 06:08 AM
