d16a6 Timing Belt Change
Thx for the replies...was wondering if this timing belt kit is any good
http://www.ebay.com/itm/250703391570...84.m1423.l2649
http://www.ebay.com/itm/250703391570?ssPageName=STRK:MEWAX:IT&_trksid=p398 4.m1423.l2649
it's a little over kill to be using the racing belt. you would be fine getting a regular Gates belt. Gates is the supplier/maker for oem honda belts.
timing belt, tensioner, tensioner spring, cam gear seal, oil pump/front crank gear seal, and all other accessory belts. valve cover gasket, and grommets also. is what you would need.
my advice, always get oem timing belt, and water pump. if you cheap out and get autozone or the such, you might be getting a part that is not to spec. also if it looks like you might need one, get a oem thermostat.
don't forget to also lash your valves since you have the cover off.
The oil pump isn't necessary but the seals will cost another $10 or $12 and are a 10 or 15 min more fix.. No reason not to, as you'll have the engine torn down on that side already..
Just make sure not to scratch the cam or crank surfaces that the seal sits on.. If you do, get some really fine sand paper and get to work smoothing it..
And just as a side note, my stepmom bought a wagon 10years ago for $250 because the engine smoked really bad... Went to do the timing belt on it to find out that the cam seal leaked so bad that oil got down onto the exhaust and made it look like it was smoking going down the road.. Long story short, she bought a $1200 car for cheap and fixed the issue with a $5 seal plus a tune up..
rodondoaccord
15
Mar 30, 2014 05:28 AM
