s40 into 94 vx , anything diff?
I picked up a good used s40 today
the trans in my 94 civic vx d15z1 took a dump last week
Im sure there are some differences
gear size doesnt matter
Im wondering about the speed sensor or any other connections?
will this basically be a simple unbolt and plug and go?
anything Ill have to modify?
Clutch line brackets are different. Reuse the one from your old transmission. Speed sensors are different but interchangeable and use the same plug (OBD1 is two piece with a metal base, OBD2 is one piece and all plastic) if the new transmission has a speed sensor in it use it. You will also need to reuse your top transmission mount.
The whole thing is 100% bolt in though.
hondabinge
16
Aug 23, 2013 01:21 PM
