EF Hatch Beater, to be or not to be?
Old Jun 23, 2012 | 06:00 PM
96johnson's Avatar
Default EF Hatch Beater, to be or not to be?
Got it towed to me yesterday. Battery is dead, currently seeking another. Front bumper is inside the car. Interior needs to be clean, front seat replaced, rear are okay. Car is suppose to run, but I haven't verified, because the battery is dead. Not sure of the direction, I want to go but, we will see. Sorry for pic quality.
plans:
hx's
lower car
upgrade with better oem brakes, dual purpose track and street
cluster swap
remove carpet, leave bare or replace with oem or replacement
replace seats, seen some rsx leathers got my eye on
Old Jun 23, 2012 | 09:14 PM
mtflyboy25's Avatar
Default Re: EF Hatch Beater, to be or not to be?
looks like some work...
Old Jun 24, 2012 | 10:48 AM
96johnson's Avatar
yea, it is definitely some work. we'll see what happens. slow project
Old Jun 24, 2012 | 11:37 AM
wanabebuff's Avatar
wow, rough... how much did you get it for, if you don't mind me asking? Definitely has potential, though (from what I can see), but could also have a ton of problems.
Old Jun 25, 2012 | 06:46 AM
93delsold16z6's Avatar
looks like a good deal if u bought for under 850.
Old Jun 25, 2012 | 07:00 AM
Scott91Hatch's Avatar
Good luck with whichever direction you decide to go.
Old Jun 25, 2012 | 07:18 AM
24TEN's Avatar
PHANTOM MENACE
It has one 90-93 Accord headlight...in case you haven't already noticed.
Old Jun 25, 2012 | 08:59 AM
Guardrail989's Avatar
i say def salvageable. I got my SI for 500 and it was BEAT (missmatched rims, no maintaince ever done, brakes were all screwed, paint was screwed, fenders and hood were toast... all in all ive only put about 600 into it minus the purchase price and it looks a whole lot better after only 2 months. just make sure its not a rust bucket and the body is straight then go from there.
Old Jun 25, 2012 | 02:32 PM
crx_arturo's Avatar
looks like a really good project good luck with your build in whichever direction you go
Old Jun 26, 2012 | 08:53 AM
96johnson's Avatar
well, it has happen, i think. give the car some fresh gas, tried to start a few times, waited. tried again, saw some smoke, heard puff noise, pop goes the motor, i think. engine on driver front side has yellow substance coming from between head and block. someone confirm for me, lol.
Old Jun 26, 2012 | 10:20 AM
tonylovesjdmEF9's Avatar
That looks to be gasket maker or it could be oil with coolant
Old Jun 26, 2012 | 10:22 AM
Also by the way it seems body needs majorwork but the bay looks decent most wiring isn't touched
Old Jun 26, 2012 | 10:30 AM
96johnson's Avatar
only way to check is pull the head correct?
Old Jun 26, 2012 | 04:32 PM
no check you oil if its milky its a blown headgasket it will kinda look like tha yellow stuff on the dip stick but im leaking more to a gasket maker they used
Old Jun 26, 2012 | 04:43 PM
96johnson's Avatar
thanks, will check in the morning.
Old Jun 27, 2012 | 05:12 AM
96johnson's Avatar
checked oil from dipstick, it isn't milky, but more of a grayish color.
Old Jun 27, 2012 | 05:35 AM
wanabebuff's Avatar
Look under your oil cap as well. You're looking for a frothy/milky terrible looking goo. Shine a light down the oil fill port for a better look, also.
Also, look down in your radiator for any oil.
Can you get a better picture of where the stuff is leaking from the head?
Old Jun 27, 2012 | 05:38 AM
96johnson's Avatar
i can try using old cellphone for pics, lol. thanks for your help. trying to remove seatbelt, as well. window is off track won't roll up.
Old Jun 27, 2012 | 05:51 AM
so how much did u pay for it?
Old Jun 27, 2012 | 05:55 AM
96johnson's Avatar
half a stack.
Old Jun 27, 2012 | 06:29 AM
96johnson's Avatar
pics of inside radiator looks, gunky. if that is a word, lol. checked oil filler looks to be okay inside.
Old Jun 27, 2012 | 07:57 AM
Canadian_EF's Avatar
It would be a safe guess that the head was leaking oil so they put the gasket sealer in there to bandaid it. The front of the block looks caked in oil. Looking at a head gasket or a swap.
Lol... Accord headlight. I thought of doing that years ago. Thought it would never fit. Hillarious!
Old Jun 27, 2012 | 08:07 AM
wanabebuff's Avatar
I agree, if you look at the exhaust manifold where it meets the head, it looks like a gasket maker goo, too, instead of a real gasket. But, it's also tough to say, the picture is a little blurry, but works.
To be safe, I would suggest replacing the head gasket at minimum. This time, don't use some garbage liquid gasket crap like they did, haha.
Old Jun 27, 2012 | 08:52 AM
96johnson's Avatar
accord headlight was put in with tape, lol. it's out now. can't figure out how to get this window crank thing out. not sure if i am going to swap or what.
Old Jun 27, 2012 | 09:19 AM
Nooch's Avatar
half a stack.
Sorry I'm not from the ghetto. Guessing this means $500?
Remove the head, get yourself a haynes manual, replace headgasket and either be cheap and risky and reuse the headstuds or go on majestic honda and order new ones... They're only $3 a piece, so $30 for peace of mind is amazing. A lot cheaper than the dealership.
To fix window, remove the door panel after removing the window crank arm. There's a little like almost complete C clip wrapped around it (pull the crank arm out towards you if youre sitting in the driver's seat.) You'll need a small flat head or something, it's easy. Remove the clip, pull the arm off. Then remove the door panel. Remove the stupid plastic wrap crap, reuse that if you'd like or if you think you have crazy leaks in your car (I don't so I just tossed that ****). The fix should be easy, multiple problems it could be having though so get this far and then either figure it out or come back and tell us what's going on with some pics.
