automatic harness to manual
Old Jun 23, 2012 | 11:09 AM
Pizoxic's Avatar
Default automatic harness to manual
Don't ask me to "search" I have done that and none of them helps.
I got 93 gsr harness (automatic) for my manual 97 Integra.
Will there be any problems, if I have automatic harness onto my manual swap motor? Because my reverse light does not come on at all. I'm kinda concern since my and my friend already tucked the harness onto the car.
Can anybody help me with this?
Old Jun 24, 2012 | 08:24 AM
fcm's Avatar
fcm
Old Fart
Default Re: automatic harness to manual
Reverse lights on an automatic are switched on at the A/T Gear Position Switch at the side of the shifter on a standard they are switched on by the Back-up Light Switch mounted into the transmission.
To get it to work you will need to run a lead from the A/TGPS, [yellow/red or just yellow] to the BLS and from the BLS back to the A/TGPS, [green/black].
Your also going to need the 2pin plug for the BLS. 94
Old Jun 27, 2012 | 08:37 AM
ThoKMo's Avatar
https://honda-tech.com/zerothread/2304301
this is a conversiom for a 93 but it might help a little
jahmesz
Jun 9, 2016 10:57 AM
DelSlowmo
Feb 11, 2010 06:16 PM
turbojdmsol
Nov 6, 2009 10:27 PM
stackz
Sep 5, 2007 09:06 AM
