1997 Civic Dx Speedometer quit working.
Old Jun 23, 2012 | 04:31 AM
AJHS2011's Avatar
Default 1997 Civic Dx Speedometer quit working.
The motor is a d16y7 4 speed automatic.
The Speedo use to work just fine then occasionally it would quit. A few minutes later it would start back working just fine. It did this for a few days and all of a sudden now it doesn't work at all.
I don't have a diagram for the under dash fuse box so if I need to do something down there, let me know what.
Thanks in advance.
Old Jun 23, 2012 | 04:50 AM
Former User's Avatar
Default Re: 1997 Civic Dx Speedometer quit working.
Any CEL codes? Any other problems?
Old Jun 23, 2012 | 07:52 AM
AJHS2011's Avatar
No CEL's and it's runs great. No issues whatsoever besides needing an alignment.
Old Jun 23, 2012 | 08:12 AM
Does the CEL work?
Old Jun 25, 2012 | 03:26 AM
AJHS2011's Avatar
Does the CEL work?
Hmm....I'm amusing so but I don't know for sure. Are you talking about the bulb or a wiring issue?
FYI the speedometer started working again last night and worked all the way home (30miles).
Old Jun 25, 2012 | 04:39 AM
When the key is turned from off to ON(II), the CEL should turn on and then off after 2 seconds, if no codes are thrown.
Old Jun 28, 2012 | 07:29 PM
AJHS2011's Avatar
The CEL does not light up at all. So I need to replace the bulb in the cluster?
Old Jun 28, 2012 | 08:21 PM
The bulb was probably removed to hide a CEL problem, or the bulb is just blown.
Old Jun 28, 2012 | 09:40 PM
Boost>NA's Avatar
Check your VSS(vehicle speed sensor). Try one you know is working if possible. Also check the connectors/wires. One wire on my female connector(harness end) eroded and all I had to do was cut it, pull the pin out, crimp it again and insert it again and it worked fine. You'rs may be loose.
Or something may be wrong with your cluster but i'd troubleshoot the other possibilites first...obviously after changing your CEL bulb first..
Old Jul 13, 2012 | 10:48 PM
AJHS2011's Avatar
Alright. Took the cluster out and found that the entire socket was missing for the CEL light. Replaced it and found codes 17, 65, and 91.
So I checked all of the fuses which all checked out fine.
Then I looked at the VSS and found that the points were all corroded and broken off. So I bought me a new VSS and I'm going to the junkyard to get a plug. Should have everything fixed by the 18th.
Stay tuned.
Old Jul 14, 2012 | 01:45 AM
Double check whether 7.5A dash fuse 15 is blown.
Old Jul 19, 2012 | 04:51 PM
AJHS2011's Avatar
Update: All the fuses were good. Wired up a basically brand new plug and installed a brand new VSS.
Speedometer now works!
OregonDucks
20
Nov 3, 2015 09:08 AM
david2450
22
Jan 23, 2013 06:37 AM
preludedriva
10
Sep 12, 2010 05:51 PM
domenic
Sep 22, 2009 06:32 PM
M2B4
Jul 8, 2007 01:43 PM
