About Intake Rotor
Old Jun 23, 2012 | 04:26 AM
Records's Avatar
Default About Intake Rotor
I was wondering how you could properly check for turbo failures? I understand that the intake 'Rotor'/'Blade Fins' may move like 0,1cm right? (Dont know the exact number though)
The question is because I've noticed that the new turbo I received that the intake rotor does move a LITTLE so dunno whether that should be alarming or not
Thanks
Old Jun 23, 2012 | 05:29 AM
TheShodan's Avatar
Moderator
Default Re: About Intake Rotor
Please check the FAQs at the top of the forum to answer this question. The title is in Grey
Old Jun 24, 2012 | 09:24 AM
Records's Avatar
Couldnt find, perhaps u can add a link? o.O
Else perhaps someone else know whether it is good or not?
Old Jun 27, 2012 | 05:04 AM
Records's Avatar
I've got my answer already though. When you attach the turbo to your engine, n get it oiled up, the movement will dissapear, correct? ^^
Old Jun 27, 2012 | 05:10 AM
wantboost's Avatar
Who is Mr Robot?
Not all of it. Turbos always have small amounts of shaft play, around a mm or less... I can't remember the exact measurement.. The number is different between journal and ball bearing Turbos. This little gap is here so the oil has somewhere to go when it enters the center section. The wheels should stiffen up and bit.
It sounds like you have the turbo just laying around so here's how to test this. Flip the turbo over until the oil drain points up, fill the center section with oil and let it sit for a few minutes and then turn and try to move the wheel. As stated most of the play should be gone but not all of it as the oil is not pressurized.
Old Jun 27, 2012 | 05:32 AM
wantboost's Avatar
Who is Mr Robot?
And these are the faq's (frequently asked questions) for future reference they are stickied to the top of the first page. The threads that are highlighted in grey are stickied topics. You can find a lot of helpful information in these threads
https://honda-tech.com/forums/forced-induction-16/%2A%2A%2Aforced-induction-forum-faq%2A%2A%2A-1024174/
matmcg
Sep 16, 2007 04:45 PM
canuk-sol
Jul 11, 2005 12:07 PM
masterasia
May 12, 2004 06:37 PM
SleekBlkPrelude
Feb 15, 2003 10:48 PM
