ITR to Si Cluster Swap
Old Jun 22, 2012 | 02:09 PM
gramkrackers's Avatar
Default ITR to Si Cluster Swap
Yes the title is correct. When I bought my Civic (98 EK Hatch) it had an Integra Type R cluster in it even though the motor is just a plain old B20B. Not sure why anyone would do that but anyways. It was driving me nuts at the track that my tach did not have the right RPM range. I picked up a cluster out of a Canadian Si (which is an EX in the US?) and swapped it in. Everything works perfectly except my odometer and speedometer. The pin is in the right slot I have double checked multiple times. Any thoughts?
p.s. I have access to a crappy cluster with no tach so if my speedo is just straight up broken I could just swap the two correct?
Old Jun 25, 2012 | 03:06 AM
grumblemarc's Avatar
The Grumpiest
Default Re: ITR to Si Cluster Swap
My thought: Find an SI to ITR cluster swap DIY and then do the reverse.
Old Jun 26, 2012 | 03:35 PM
I did that, but thanks......
Old Jun 26, 2012 | 04:26 PM
The Grumpiest
Sorry. You didn't mention exactly what you did.
Old Jun 26, 2012 | 04:37 PM
ReedMann's Avatar
The speedos between all 96-00 clusters are interchangeable. I would try that and see what happens.
mugenpowered
12
Apr 29, 2006 02:01 PM
97civicsedan
Jul 9, 2005 07:46 PM
RJH6
Apr 27, 2005 07:13 AM
JSPECEX
Mar 23, 2003 07:53 PM
