anyone done a line-lock on a integra
Old Oct 14, 2002 | 04:44 PM
turbotypeR@SPEC's Avatar
25 Year Member
Default anyone done a line-lock on a integra
i am doing a tci roll-stop on the rear brakes of my car.my question is,in the book it shows a primary and a secondary brake line coming from the master cylinder.i assume the primary is the front and the secondary is the rear.does anyone know for sure before i cut this thing up?
Old Oct 14, 2002 | 05:07 PM
kinesistech's Avatar
Default Re: anyone done a line-lock on a integra (turbotypeR)
The brakes are divided into 2 circuits. One is left front and right rear, the other is the other right front and left rear. If you want to use a line lock you need to put it after the proportioning valve to the rear only. You'll probably only be able to lock one wheel though.
Old Oct 14, 2002 | 05:12 PM
25 Year Member
Default Re: anyone done a line-lock on a integra (kinesistech)
thanks.that is what i was afraid of.i think it will still work fine though.i am having trouble staging without rolling through the lights
Old Oct 14, 2002 | 05:28 PM
I think one wheel should be enough for staging.
rajan
Nov 2, 2016 06:01 AM
kelley_james
Oct 21, 2012 04:46 AM
EKSedAndy
Apr 30, 2008 04:37 PM
b18ccivics
Aug 20, 2006 06:22 AM
ButterMule
Sep 4, 2004 08:42 PM
