95 Civic/D16Z6/P72 ECU - Idle problem
Old Jun 22, 2012 | 06:18 AM
TAZ95's Avatar
Default 95 Civic/D16Z6/P72 ECU - Idle problem
ive got a 95 hatch with a d16z6 engine. the engine has 11.2:1 pistons, .401 .441 lift cam, skunk2 intake manifold, and a blox 68mm throttle body. im currently running a stock automatic gsr (P72) ecu. the engine idles around 2200-2500 rpm for about 5 minutes the idles up and down between 1500 and 2,000 rpm. the vacuum hose going from the evap canister to the trottle body has been plugged off because there wasnt a place for it on the throttle body. Ive replaced the intake temp sensor and tps sensor. it isnt throwing any codes. it runs fine just has idling issues. if i unplug the idle control valve it idles around 1200 rpm but bucks if your driving through a parking lot at around 1500 rpm. any ideas or help would be appreciated. thanks
Old Jun 22, 2012 | 06:40 AM
grumblemarc's Avatar
The Grumpiest
Default Re: idle issue
Why are you running a stock ECU for a DOHC on a SOHC with all those mods? Is that a recommended combo?
Old Jun 24, 2012 | 05:11 AM
TAZ95's Avatar
it was all i had untill i get my chipped p28...the engine now knocks at start up then ticks...it has power until 4500 then acts like the engine is struggling to open up.
Old Jun 24, 2012 | 05:39 AM
Former User's Avatar
Stop driving the car until you install the correct ECU.
Also stop throwing parts at it without doing any troubleshooting.
Did you block off the disconnected vacuum hose?
Are any CEL codes thrown?
Old Jun 24, 2012 | 06:49 AM
TAZ95's Avatar
the only codes it gives me is an oxygen sensor heater circuit and vtec solenoid check. code 21 and 41
Old Jun 24, 2012 | 06:51 AM
The Grumpiest
egkid1
Jan 28, 2013 04:12 AM
lalocivic
May 23, 2009 09:33 PM
NA_B_FTW
Feb 11, 2009 12:06 PM
chillly
Apr 15, 2002 07:00 PM
