K24z3 in 95 coupe
Old Jun 21, 2012 | 11:21 AM
griff12's Avatar
Icon2 K24z3 in 95 coupe
I have the opportunity to get a k24z3 out of a 2009 accord lx with 28k. It was a friend of mine who had the car totaled from the rear. Would it be worth putting in what would i need for the install? i'm more a single jingle an bseries guy. Just sold my gsr an put the stock d15 back in for now. Also debating going back to bseries, but don't have much experience/knowledge on k's so wondering if that would be my better bet? i'm looking for some reliable n/a then eventually go f/i. Thanks!
Old Jun 21, 2012 | 11:25 AM
JuggerNaut-CTR's Avatar
Default Re: K24z3 in 95 coupe
Have you even tried to search to searching here? K-swaps are k-swaps.....found plenty of how-to swap & k build threads just useing the search. Literally took 15 seconds worth of typing, clicking, and looking.
Old Jun 21, 2012 | 11:29 AM
griff12's Avatar
I have done searching. The post is more for opinions on if it's worth while an the extra$ vs bseries most likely c1 or ls/v
Old Jun 21, 2012 | 11:43 AM
grumblemarc's Avatar
The Grumpiest
It's up to you if it's worth it. No one else.
Old Jun 21, 2012 | 11:46 AM
k-swaps are cool regardless which one you have. k24z3 is 190chp and 162ft/lbs. Not really argueable that would be more fun than a gsr or lsv. The z3 peaks power @ 7000rpm. Redline is 7100. All that motor needs is valvetrain and cams and it would be fun fun fun. With how long k-swaps have been around now, they really arent even all that expensive anymore. Over 2 yrs ago there was a guide made on how to swap a k for $3000 or less. With all the parts that can be sourced thru these forums, I would try and go K-series
Old Jun 21, 2012 | 11:57 AM
griff12's Avatar
ok, cause like i said i'm use to b's but would like to try the K world. I've heard the z3 is tough to mod with though because there not that compatible with older K series parts. True? That's the other thing I'm considering is the availability of parts.
The Grumpiest
Jeez. K20a.org. Go there.
Old Jun 21, 2012 | 10:31 PM
doood's Avatar
been there done that
you do not want that engine in stock form. the best k swaps are 02-08 k20a/2/z1/z3, and the various k24 variants.
Old Jun 22, 2012 | 06:09 AM
griff12's Avatar
yea, after more research i'm coming to realize that. Thank you. maybe i'll just sell the motor an put it towards an earlier K or stick to B-series which i'm comfortable with.
Old Jun 22, 2012 | 03:52 PM
K20 junkie's Avatar
If you're gonna go k series go With a k20a2 Don't waist time an money on an accord swap just dynod my ek k20a2 turbo an pushed 483whp on a stock motor just injectors an fuel pump
Old Jun 25, 2012 | 12:58 PM
griff12's Avatar
wow, what will those blocks handle stock?
Old Aug 30, 2012 | 12:09 PM
erbavour's Avatar
Post Re: K24z3 in 95 coupe
Whichever it is, it is a stepup from d,b, or h. Keep in mind the k24z3 has the filter at bottom attached to girdle and not at top right backside of block. If you decide on using a k20 oil pump it could be alittle more work=money to complete this type of project. Either way homie a K is Monster in a eg,eh,ek chassis. A straight swap with that z3 and ur making POWER. Good luck man
JDM_MOB
Feb 5, 2011 08:45 PM
jaron711
10
Mar 21, 2010 02:56 PM
Egyptian_Kid
77
May 24, 2007 05:57 PM
