z6 vtec CEL code 22 HELP!!!!!!
Old Jun 21, 2012 | 08:51 AM
brandynEG's Avatar
Default z6 vtec CEL code 22 HELP!!!!!!
I have a 92 civic vx hatch and it has a z6 swapped into it. its throwing a CEL for vtec oil pressure switch and I can not get it to go away. my oil level is fine, there is a new gasket on the solenoid, and I even tried hard wiring the pressure switch right to the ecu, but its possible I did that wrong. anybody have any ideas or know what else to try? thanks.
Old Jun 22, 2012 | 05:24 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: z6 vtec CEL code 22 HELP!!!!!!
https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%22my-vtec-doesnt-work%22-1812135/
Old Jun 22, 2012 | 10:24 AM
brandynEG's Avatar
fixed it, but now I have a code 6... which I had before the vtec CEL. hmmmm ...
Old Jun 23, 2012 | 07:28 PM
brandynEG's Avatar
bump
Old Jun 28, 2012 | 07:36 AM
brandynEG's Avatar
bump.... still have a code 6 for ect sensor. will this cause vtec to not work?
Old Jun 28, 2012 | 01:45 PM
Technical Hero
Yes, and what colors are the wires going into the sensor. Do you know which sensor is the ECT sensor?
Old Jun 28, 2012 | 04:46 PM
brandynEG's Avatar
off the top of my head I'm not sure... when I first got the car running, it was throwin a 6... and I could NOT get it to go away. and idk what I did but one day the code 6 was gone and I had a code 22 for vtec pressure switch. the wierd thing about the 22 is it would go away sometimes while I was just driving. so I hard wired my vtec to the ecu and it started throwing the 6 again.... WTF?!?!?!?! do these sensors share a common ground at the ecu?
Old Jun 28, 2012 | 06:23 PM
Technical Hero
Post a pic of those sensor
LS Turbo300
Feb 27, 2014 04:50 AM
LS Turbo300
Aug 23, 2012 04:47 AM
Ran4it2
Aug 17, 2009 11:53 AM
aZnjCC
Oct 16, 2005 03:18 PM
