eg hatch with gsr dash CEL doesnt work...
Old Jun 20, 2012 | 09:38 PM
efyaki's Avatar
Default eg hatch with gsr dash CEL doesnt work...
hey guys jusy bought a eg hatch that has a gsr dash in it and the CEL doesnt come on at all when you turn to key over to power. i dont know how about going to get this fixed because i have never done in install like that and was wondering if anyone has any ideas? thanks
Old Jun 20, 2012 | 09:42 PM
JuicedUpRice's Avatar
Default Re: eg hatch with gsr dash CEL doesnt work...
the ecu not showing anything is a very common sign that the ecu is faulty..
Old Jun 20, 2012 | 09:50 PM
jbpnoman's Avatar
Pull out the cluster and see if the PO removed the CEL bulb. Common sketchy way to sell a car with problems without telling the buyer.
Old Jun 20, 2012 | 10:24 PM
efyaki's Avatar
car runs fine just doesnt show the check engine light just wanna make sure there isnt any CEL's or any future ones. i checked the bulb and its in there and even switched it with another bulb
Old Jun 20, 2012 | 10:29 PM
well the ecu should have a light on it that will flash red if you have a code.under the passenger carpet under dash..
Old Jun 20, 2012 | 10:36 PM
efyaki's Avatar
its a p72 ecu there is no red light on the ecu
Old Jun 20, 2012 | 10:40 PM
jbpnoman's Avatar
That's only OBD0 ECUs, IIRC.
OP, when you jump the service connector, does the CEL come on?
Old Jun 20, 2012 | 10:53 PM
efyaki's Avatar
no it doesnt come on im wondering if the wiring in the cluster since it has a gsr dash and cluster isnt wired right?
Old Jun 20, 2012 | 10:54 PM
jbpnoman's Avatar
It sounds like there's a problem in the wiring between the ECU light and the ECU. Your best bet would be to get a wiring diagram for the gauge cluster you have, and see where what's in the place of the wires that should be there.
Old Jun 21, 2012 | 08:28 AM
Former User's Avatar
Does voltage reach the CEL bulb socket with the key in ON(II)?
Crashmaster91
Jan 31, 2013 02:23 PM
Eg-Jav
Jan 3, 2013 11:49 AM
Cameron11
Jan 26, 2012 04:11 AM
dapek
Dec 1, 2008 09:38 PM
