Civic No Power
Old Jun 20, 2012 | 03:51 PM
99SiGuy.'s Avatar
Default Civic No Power
Hey guys, i have been searching for the past few days about this.
My 99 Si just dies after i turn the key to start it.
When i get in the car, and i put my key in the door chimes. Then when i turn the key one click the radio omes on, two clicks my radar detector comes on and sometimes the dash lights light up, but as soon as i turn the key one more click to start it, everything dies.
One strange thing is if i keep the key in the first postion with the door buzzing and the dome light on, and i press the brake pedal, try and honk the horn, or turn the lights on it kills it.
I replaced the ignition switch, and checked the battery. I am going to check the Main relay, and also check the ground by the thermostat tomorrow.
This is puzzling me and if anyone has any ideas i would appreciate it!
Thanks!
Dan
Old Jun 20, 2012 | 03:55 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Civic No Power
How did you check the battery? Grounds clean?
Old Jun 20, 2012 | 03:58 PM
MMMGIRL's Avatar
Check your ground wires, sounds like it could be a potential ground.
Old Jun 20, 2012 | 04:05 PM
99SiGuy.'s Avatar
I used a multimeter, and also took it by the autoparts store this afternoon while i was running some errands.
Ill have to double check the grounds.
Old Jun 20, 2012 | 04:10 PM
MMMGIRL's Avatar
I work at Advance Auto and let me be the first to tell you the battery testers are not always 100" accurate. It could read good battery one minute with 500 CCA then the next drop to 400 CCA and so on. Try jumping the battery off and seeing if it will start, if not look into your grounds.
Old Jun 20, 2012 | 04:18 PM
99SiGuy.'s Avatar
Yeah the first thing that i did was try and jump it.
Ill have to check all my gounds
Old Jun 20, 2012 | 04:21 PM
MMMGIRL's Avatar
Dont forget you have a ground by the thermostat housing
Old Jun 20, 2012 | 04:23 PM
99SiGuy.'s Avatar
yeap thats the first one that i am gong to check! haha read too much about that one.
superman832
Honda Civic (2006 - 2015)
Feb 28, 2013 09:54 AM
kyler253
13
Oct 24, 2012 03:50 PM
x69tooshort69x
Aug 12, 2008 05:23 PM
1999 honda Accord Cali
Jun 17, 2008 06:18 PM
Pockets
Dec 19, 2007 05:24 PM
