Source of oil burn?
Engine is a D15B2. 194k miles. Burns about 1 quart per tank of gas.
1. Absolutely no leaks under the car.
2. Checked and changed the PCV.
3. Checked the spark plugs, they are all absolutely clean.
4. Pulled the oil cap while hot and running, no smoke or evidence of bad rings.
5. Compression tested perfect.
6. Checked the air intake, absolutely no evidence of oil.
What other tests could I do?
yeah my buddies 90 laser rs turbo has 300k on it stock stem seals, oil litterally pours out of the exhaust stem seals (just on cylinder 3) and into the turbo and out the exhaust (it drips out of the exhaust manifold gasket if he doesn't tighten it down super hard. any ways the point is stem seals wear out and oil can leak past them into the exhaust or intake, and are a wear item. not TOO hard if you know what you're doing you just have to pressurize the cylinders (take the schrader valve out of a compression tester and use compressed air on the end) to keep the valves seated and closed
user 98292739
Feb 21, 2005 12:01 PM
