What is this? *pic*
Old Jun 19, 2012 | 06:31 PM
Draggin99Si's Avatar
Icon6 What is this? *pic*
There's this orange hose to the right of where the battery sits. What is this hose for?
There is a white clip that plugs up the hose opening that broke off which needs to be replaced.
Identify this hose as I am completely stumped.
Old Jun 19, 2012 | 06:43 PM
MikesEJ1's Avatar
Default Re: What is this? *pic*
looks like some kind of drain hose or maybe a....wow i'm also stumped
Old Jun 19, 2012 | 07:37 PM
Jdmbryan's Avatar
pull the battery tray out and see where it goes lol
Old Jun 19, 2012 | 07:41 PM
Fliptard's Avatar
It is just a breather hose for the vac system. It just vents air from a black box that hookes to the fuel tank and crankcase to relieve pressure.
Old Jun 19, 2012 | 08:06 PM
I'm trying to replace the top white plastic piece that plugs into this hose.
Do you know where I can find it on this parts diagram?
http://www.hondapartsdeals.com/hpa_p...onGroupID=1586
The hose is illustration #64, and the hose plug that I need is #16.
Does this sound correct?
Old Jun 20, 2012 | 01:33 AM
Arts09's Avatar
I would think its the condensation hose for the ac system lol
Old Jun 20, 2012 | 02:15 AM
MRGRIM's Avatar
R.I.P. Mark
part 16 is correct
the peice your after could be easly got from the junk yard
it pushes into the end of the fuel vapour breater hose and
clips into the square hole in the side of the fuel filter mounting bracket
as you can see the hole in your pic right hand side middle
Old Jun 20, 2012 | 02:59 AM
jbpnoman's Avatar
Unless you're OCD about things being perfectly OEM under the hood, that little clip is unnecessary. Just wedge the hose somewhere nearby. I have mine wedged between the firewall and fuel filter, and have for the past two years without problem.
Zendos
Nov 3, 2009 04:34 PM
Dee888
Apr 22, 2008 08:04 PM
crxpwr1
28
Jan 24, 2007 06:47 PM
japspecjohn
10
Sep 19, 2004 01:15 PM
sacredc0w69
Aug 26, 2003 08:42 PM
