91 si hatchback vs 92 si hatchback
What's up Honda tech. I have some questions for all you. I own a 92 hatchback si stock engine, and i just bought a 91 si hatchback with a b16a1. I was thinking in swaping the engines, but i want to know if i need to get new motor mounts harness, ecu etc for both, or are all the parts compatible?
Any advices and suggestions are welcome.
You'll need another distributor, O2 sensor, ECU, motor mounts, shift linkage and hydraulic transmission. It would really make a lot more sense to just find an OBD1 or OBD2 B16A or some other B-series.
what things can i use from my 92 with the b16. i was thinking in buying another engine for but i couldnt find any. thats why i choose to buy the 91 and swap the engines. I think that way is cheaper than just buying the engine by itself for 15k or 2k.
so i dont want to sound stupid, but this is my first time swapping engines could you help me with this. It will help me.
I want to know what parts ill need for the eg from the ef(b16a1) and also what other parts would i need to buy.
And for the ef from the eg(d16z6). what things will i would need to buy and what things will work with the ef
really all you need is motor mounts and linkage which both can come from a dc integra as well as a tranny but you could even just buy a hydro to cable kit off ebay for cheap in the mean time. im assuming thr EF is converted to OBD1 ?
C00kiemunstr
Oct 11, 2008 08:59 AM
