Immobilizer question YET UNASKED!!
Been searchin for a week, haven't found this answer:
I have a 2000 DC2.
My GF decided to customize it for me by rolling it a few times across a freeway
'wtf!'
SO:
Picked up a 95 DC2 theft recovery clean title.
(obd1)ECU, Cluster, Seats, fuel pump, front suspension, rims, engine/tranny, AC (engine compartment only) GONE!
The Question:
Obviously I'm swapping the motor/trans/interior/ac/etc over from the 00-DC2.
I will purchase a OBD1 ecu so i can pass emmisions. Not worried about that.
I would like to eventually use the OBD2b ECU (will require adapter harness i already know) primarily for better efficiency and hopefully the immobilizer system too.
Since the 99 and below have no immobilizers in them, IF i use my 00 Ignition switch AND ecu (and cluster of course), what else will I need to do to make use of my existing immobilizer system (currently in the totaled car)?
Will I have to swap the entire Chassis Wiring Harness (except maybe heat/tail light and ABS harnesses)??
Has anyone done this successfully (or heard of someone pulling it off) before?
THANKS!
I have a 2000 DC2.
'wtf!'SO:
The Question:
THANKS!
If you have to swap in the obd2b underdash harness for it to work, just get an alarm system.
EVERYTHING is different(plugwise) when you jump into obd2b for a Dash/Underdash/Doors/Body harness.
So if you have to swap dash and underdash harness, it's not really worth the effort.
