Can I use rattle can primer before i paint with a paint gun?
Old Jun 19, 2012 | 07:58 AM
6thgenftw's Avatar
Default Can I use rattle can primer before i paint with a paint gun?
I have a front lip that i want to paint and i want to paint it with my paint gun. Can i use rattle can primer and clear coat or should i get some i can spray with my gun? (noob painter here)
Thanks in advance
Old Jun 19, 2012 | 10:25 PM
j13's Avatar
j13
Default Re: Can I use rattle can primer before i paint with a paint gun?
Yes you can
Old Jun 20, 2012 | 03:52 AM
6thgenftw's Avatar
sweet thanks
Old Jun 20, 2012 | 08:54 AM
joeshmo's Avatar
Actually, it isn't quite as simple as that. It depends on what your color coat is, which you haven't told us. If it is a urethane, then no, you may not paint it over rattle can primer.
Old Jun 20, 2012 | 10:50 AM
6thgenftw's Avatar
Oh... Well I just got a quart flamenco black pearl paint from Napa
Old Jun 20, 2012 | 10:54 AM
joeshmo's Avatar
Is it a non-activated urethane basecoat? If so, you may be fine putting it over the primer. I would try a bit on a test panel to make sure it doesn't bubble up. What kind of primer did you use?
Old Jun 20, 2012 | 01:27 PM
6thgenftw's Avatar
i haven't done anything to the lip yet but sand it. What does non-activated urethane base coat mean?
Old Jun 20, 2012 | 04:51 PM
Tony S.'s Avatar
Did the paint come with or require a hardener? If not then it is non-activated.
Old Jun 21, 2012 | 03:32 AM
6thgenftw's Avatar
^No it didn't the guy said its base coat/clear coat paint
Old Jun 22, 2012 | 05:17 AM
6thgenftw's Avatar
Forget rattle can primer... What brand/kind of primer and clear coat should i use on this polyurethane front lip?
Old Jun 22, 2012 | 06:46 AM
95dxdrivr's Avatar
Just my 2 cents, this is what i would recommend to my customers.
first off there are several ways to do this, these are just a few suggestions I can give you.
you will want to use a flexible primer made for plastics, or a adhesion promoter followed with a primer that has a flex agent added, depending on whats available to you.
Biggest thing I would stress is your prep work! any raw plastic part will need to be cleaned, sanded and then cleaned some more. Several companies make products for this. some call them 'plastic cleaning paste' others may label them 'abrasive cleaning paste'. (can also use Dawn dish soap unsented with a scotch pad if money is an issue) A simple test to check if it still has mold release on it is to take a some water and spray it on the surface, if it beads up then you need to clean it some more, if it rolls of the surface in a sheet then you are doing ok.
As stated above any activated primer, or 2K primer will perform better than a single component primer.
But it all depends on what you want to spend, how much time you want to invest, and the general out come your are trying to acheive.
Old Jun 23, 2012 | 04:53 AM
6thgenftw's Avatar
^thanks man appreciate it im going to get some more sand paper, plastic cleaner and 2k primer then
Old Jun 23, 2012 | 06:53 AM
Skalabala's Avatar
95dxdrivr summed it up nicely
EG-SIXV-TEC
Paint and Body
13
Sep 7, 2011 07:19 PM
FishyMan
Paint and Body
Feb 28, 2009 06:17 PM
jaydem7
Paint and Body
Sep 11, 2007 10:52 AM
deeweezy
Aug 17, 2003 07:19 AM
Rising sun #1
May 6, 2003 11:49 AM
