Just put a deposit down on an Accord with the check engine light on...
Sounds stupid I know...But the car was in beautiful shape and the carfax was one owner and literally the tightest I have ever seen...
So from what I have gathered here, it is an ODBI (94 with 160k 5-spd), and thus I can read the code on the dash. So I will get to do that in a couple days after the current owner gets the title together etc.
Anyway there were some slight symptoms, maybe since you guys know Hondas well you can perhaps hypothesize on what's wrong.
1) The car seemed to run a little cold, as if the thermostat was stuck open a bit, the coolant temp would not go to midway, only about 3/8 and it did so in a notchy fashion.
2) It idled low...it did not stall. just idled down near 700rpms and fell down there somewhat quickly after you took your foot off the gas.
3) There was a bit of a sticky lifter noise when I started the car up, but the car was on a steep grade node up, thus I believe depriving it of oil when it started, and the noise did go away when we were on smoother ground. (I think this is just older car and unrelated to the CE light.)
other than that it was choice and I had to buy it then and there or I knew the next guy would. Anyway, I'm hoping that a bad thermo hasn't been running in the car long enough that it gunked up the cat and threw the code. Anyway, you guys have any insight?
thanks
thanks
I'm sorry. Did you read my post fully and understand me? because in the second paragraph there is something of a disclaimer saying just that I won't be in the presence of the car for a couple of days. This is a discussion forum, not a reference site. I am not very familiar with Honda's and all I did was reach out to ask if anyone had experienced a similar bundle of problems.
like I said thanks, there is really no reason you need to pursue this discussion any further, hopefully someone with something constructive to add will chime in
Check the Accord FAQ for details
Under the glove box is a two wire blue connector, jump the wires with a paper clip and turn the car to ON(not start) the CEL will blink for a given code(s). FAQ has the list of CEL codes.
Thanks guys,
Ok got out there yesterday and checked the codes:
It looked like it was throwing code 41 - O2 sensor repeatedly...
When there is only one code will it continue to throw the same code over and over again indefinitely? That's what seemed the be happening.
If that's the case I am relieved it's such a minor issue I got a great price on the car.
yes, when reading the CEL for codes, it will always repeat. If there is only one code it just repeats that one code over and over. If there are multiple codes it will cycle through each code and then start over and over again.
Awesome, thanks for the response.
One other thing, I was looking around amazon for a good repair manual and there's a few different ones with mixed reviews, is there any particular one board people would suggest?
crowdcor225
Mar 19, 2013 07:41 AM
FunkTechNician
Feb 1, 2011 02:31 PM
zak88lx
Jun 5, 2007 01:33 PM
J-Ra
Aug 18, 2005 07:08 PM
