Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
Blackworks Coilovers from Redline360
Old Jun 18, 2012 | 09:23 AM
RedlineMotive's Avatar
Default Blackworks Coilovers from Redline360
The New Blackworks Coilovers feature a wide range of height adjustments without changing the spring compression and sacrificing the shock stroke. Traditional Coilovers requires the movement of the spring perch to determine the ride height, causing a reduction in suspension travel and induce coil spring binding. The bottom shock fork / connector is threaded to allow height adjustments to each drivers need without having to shorten the suspension travel by maintaining the original spring perch location. With this function, each driver can lower the center of gravity to achieve better handling, without sacrificing ride quality.
These Blackworks SS coilovers provides height adjustments, damping force not adjustable suspension on the SS version
WARRANTY: BWR offers a limited 3 year. warranty on all of our coilovers when purchased from an authorized dealer such as Redline360
SPRING RATES:
Front 10KG (560lbs)
Rear 6KG (336lbs)
COMES WITH 6061 ALUMINUM UPPER MOUNTS
Blackworks Coilovers Honda CRX (1998-1991) SS-HD15
Blackworks Coilovers Honda Civic (1998-1991) SS-HD15
Blackworks Coilovers Honda Civic (1996-2000) SS-HD02
Blackworks Coilovers Honda Civic (1992-1995) SS-HD01
Blackworks Coilovers Acura Integra Type-R (1997-2001) SS-AC06
Blackworks Coilovers Acura Integra (1994-2001) SS-AC02
Blackworks Coilovers Acura Integra (1990-1993) SS-AC01
1320fuel.com
Jan 21, 2014 03:04 PM
brndon076
Honda S2000
53
Apr 24, 2012 03:25 PM
RedlineMotive
27
Mar 27, 2012 07:11 AM
Morenci
Jun 17, 2008 09:20 AM
anjapower
Oct 17, 2002 11:46 PM
