92 accord a/c removal please help
Ok so the past week I've been getting a rattle from my ac pulley well this morning on my way to work the pulley seized up had to push the car home. I've been searching the web for hours trying to find a forum that gas the info I need. I got two bolts off of the bottom of the pump and can't find any flmore bolts that I can reach. If any one has removed one from this year gen I would be very thankfull
I got the belt off by loosening the alternater but I need to remove the pump so run the shorter belt I can't really see what I'm doing in the area in at working on the side of the road no proper lighting like I said there was two bolts I was able to get from under the car but can't locate the others
i believe the two bolts you are referring to are actually the bolts on the bracket itself you need to look on the outside of the compressor and there should be 4 bolts that kind of blend in with the compressor, i recommend pulling out the radiator so you have room to see.
4 bolts to remove compressor.
http://www.hondapartsnow.com/diagram...o-2-461687.png
Might have to remove the fan and/or radiator to get clearance
wait shorter belt for what? my 91 accord has a single belt for the a/c. do you have a swap? you should be able to just cut the belt off and still drive it like that. only thing is that you wont have a/c
yeah i know your right im sorry i was so tired last night i was really falling aspleep as i typed it my eyes burned so much i had been up for 17 hours straight
