Quick question about stock exhaust manifold...
nope
someone knows this!...to be more specific i am talking about the GS-R...
[Modified by FD3S, 4:03 PM 10/14/2002]
for gsr's....'94-99 are interchangeable and '00-01 are also.
rs/ls/gs and gsr are not interchangeable for any years that i know of...
[Modified by skrewloose, 2:21 AM 10/15/2002]
i thought the obd2 teg's -96up -had a o2 sensor on the header? - i know my 94 don't have any sensors on it
They have the same flange but are different lengths
and yes, the obdII manifolds have an o2 bung in them. you can use an obdI mani, but you would have to have an exhaust shop weld in an o2 bung for it to work.
ok...sorry to bring this up again, but i am needing to buy one asap. so this is what i have:
all GS-R manifolds '94-'01 will fit
'94 and '95 manifold do not have O2 bung
i have a '99 GS-R...if i want plug and play characteristics i want '96-'01 manifold and A-pipe...correct?
please help
'94 and '95 manifold do not have O2 bungi have a '99 GS-R...if i want plug and play characteristics i want '96-'01 manifold and A-pipe...correct?
please help
94-95 OBDI GSR's have one O2 sensor....I don't remember if it is in the a-pipe or cat
96-01 OBDII GSR's have two O2 sensors....I believe they are both in the cat...I know for a fact that the 96-99 ones are both in the cat.
94-99 GSR exhaust manifold ARE interchangeable because they are the same length and use the same length cat.
00-01 GSR exhaust manifolds and exhaust are a different lenght...so it is not interchangeable unless you have the cat and exhaust from a 00-01 that you will swap into an earlier year.
Just look at any header manufacturers site (www.dcsports.com) and it will list part number for specific years...it should answer your question.
EJ6-2nr
45
Jul 23, 2010 06:30 PM
SaMMaE01
Jun 29, 2007 02:00 AM
