speed sensor cel!
Old Jun 17, 2012 | 04:09 PM
Chris Takayama's Avatar
Default speed sensor cel!
i have a 91 hatch that has a 99 gsr in it with a obd1 p72 that is chipped not sure what chip is in it but i have a cel for speed sensor and need to know if there is anyway of getting rid of this cel. it has a 90-91 si cluster. can anyone help?
thanks!
Old Jun 17, 2012 | 07:23 PM
villc713's Avatar
Default Re: speed sensor cel!
Is speedo working? If not may need to fix either speed sensor or cable. Have you tried a different ecu to see if code still appears? I think you have to wire a certain wire to blue wire on dizzy I will check tomorrow for you to tell you what color it is
Old Jun 17, 2012 | 07:33 PM
91EFH22's Avatar
Yeah you need to run a wire from the ecu to the blue wire behind the cluster. I cannot remember the correct wire out of the ecu though.
Old Jun 17, 2012 | 07:36 PM
villc713's Avatar
Mines is at the dizzy but behind cluster will work just as well
Old Jun 17, 2012 | 08:22 PM
villc713's Avatar
Hey I found this online look at it it is pin (b10) vss that you will have to extend to either dizzy or cluster (blue wire) http://technet.ff-squad.com/wiring.obd1.htm
Hope that helps. Oh forgot to mention to not cut wire but add an additional wire to that on on your jumper harness.
Old Jun 17, 2012 | 11:33 PM
thanks a lot appreciate it! im also coding for crank sensor it has the MSD blaster ss cap and the coil is takin out of the dizzy would that cause it to code for crank sensor or do i just need to get a new dizzy? the car has been jumped from obo to obd1
Old Jun 17, 2012 | 11:36 PM
i just got this car the other day so and i dont know if its the wiring or not if it was wired from the ecu end wrong could that cause it? if anyone has any links to a page to help me out i would appreciate it a lot
Old Jun 18, 2012 | 10:48 AM
villc713's Avatar
Yea prolly would throw a crank code cuz of the msd but will double check on that once you get the first code dealt with un plug battery for a while to erase codes from ecu and recheck them to see wat you got left.
Old Jun 18, 2012 | 10:59 AM
Took the cat for a drive today its coding for o2 sensor, tps, vtec spool, and still for crank sensor
Old Jun 18, 2012 | 11:08 AM
villc713's Avatar
If not already installed you need a four wire o2, also check your tps with a voltmeter, with vtec spool see if the vtec gasket is clogged and clean it or get new gasket from Honda, as the crank sensor has to deal with dizzy. Also are you running a obd1 dizzy?
Old Jun 18, 2012 | 12:19 PM
the o2 sensor isnt even install in the car there is no spot in the exhuast for it so i will have to take it in and have a bung installed as far as location for the o2 sensor it has a obd1 jumper does it need to go in before the car or after that cat? it has an obd1 dizzy how to do you check the tps with a volt meter? thanks for all the help
Old Jun 18, 2012 | 03:06 PM
villc713's Avatar
There are stickys on this site for checking tps use the search bar up top, as for o2 they usually go before the cat hopefully this helps because idk which harness you are using
http://www.locashracing.com/instructions/OBD0-OBD1.pdf
perry2929
Sep 20, 2013 08:08 AM
foxdecoy
Aug 21, 2009 03:41 PM
jakscivic
Aug 17, 2008 10:53 AM
Adamd
Jun 25, 2008 05:54 AM
95gsrteg
Mar 18, 2005 11:23 AM
