what temp sensor controls the fans?
Old Jun 17, 2012 | 02:35 PM
Thepowderblue's Avatar
Default what temp sensor controls the fans?
My fans only turn on after I turn the car off. I think its the temp sensor. Is it the one on the waterneck or thermostat housing?
Old Jun 17, 2012 | 11:45 PM
holmesnmanny's Avatar
Default Re: what temp sensor controls the fans?
The thermostat housing in the back passenger side of the engine. It's normally called a "fan switch"
Old Jun 18, 2012 | 09:11 AM
redbull-1's Avatar
The thermo-switch A (aka fan switch A) is located on the thermostat housing (connected by the lower radiator hose). Normally, when the car is on even if the A/C is off, when the coolant temperature reaches ~ 194 degrees at thermo-switch A, both fans (A/C condenser fan and radiator fan) should turn on. If A/C is turned on, both fans should run regardless of the temp. at thermo-switch A.
After the car is shut off and if the coolant temperature at thermo-switch B (located at or near the upper coolant hose housing on the engine block) reaches ~ 223 degrees F, then the radiator fan come for a set amount of time.
Old Jun 18, 2012 | 02:19 PM
...but not longer than 15 minutes due to fan timer.
dhonda00
Jun 11, 2013 04:14 PM
gitarman2
May 26, 2013 03:58 PM
Fighterinsnatch
14
May 26, 2007 08:18 PM
Cuda
Mar 21, 2007 11:25 PM
h2392si
Jan 2, 2006 09:18 PM
