Full Race Traction Bar, Innovative Mounts, B18CR, CRX
On Full Race's website they say B-Series swaps with Hasport mounts. Not sure why they explicitly say Hasport. I have seen only a couple of issues with the Full Race bar's radius arms touching the crank pulley, but I think those were D-Series.
Additionally, I have a full size Koyo radiator, and JDM Type R headers.
So here is the list of parts I am worried about fitting together:
JDM 98 spec B18C type R with Oem headers
Innovative Mounts
Koyo full size radiator
Innovative AC adapater
**Full Race Traction Bar
**Have not bought yet.
Innovative Mounts
I have avid mounts and the full race traction bar. It did hit the stock B16 pulley. I'm running an underdrive unit and it's fine now. Also have B-series a/c, but only one fan.
What underdrive pulley do you have? They only ones I can find are singles just for the alternator, then triples with AC and PS. I would buy a double one if I could find it, just to be safe.
I have a triple aluminum underdrive I found on ebay. Some people will say it's not balanced, but honestly it's lighter and better made than the CTR pulley. I've run both for years. I don't use the PS rib, maybe someday I'll shave it down.
just to be safe? not understanding that. i have an innovative traction bar with hasport mounts and have zero issues with the stock gsr pulley. one simple alternative is to get your stock pulley shaved down to just the alternator belt and balanced. was someone on h-t that did it, not sure if they still do
couldn't find the thread, but apparently inline4 does it
http://www.inlinefour.com/infourn1encr.html
$100 plus shipping your own pulley? Or $150?! That seems high to me when you can get a new CTR/N1 for about $60.
Not exactly the same but I have.
B18CR
Hasport mounts
ETD traction bar
Mishimoto full size radiator
RMF replica header
AC
etc...
Still have the stock pulley.
B18CR
Hasport mounts
ETD traction bar
RMF replica header
AC
etc...
did you modify the bottom of your radiator? a friend of mine is using a different brand of traction bar (full-race) and he had to modify the lower part of his mishimoto full sized rad. im planning of getting a traction bar and will use a full-sized koyo rad, problem is i dont want to modify anything on the radiator.
hmmm... I have the Innovative Traction Bar and Innovative Mounts. No radiator mod needed (Running Dual Core Half Rad), no pulley mod needed.... no no no needed. All works perfect! Running a B18B Boosted with stock LS Triple pulley, but only using alternator belt.
Are you guys prety happy with the traction bar? Does it make a major difference making it worth buying for a street car?
I'm in for information on all of this, I'm tired of my current hatch and will probably end up swapping for a CRX or wagon soon.
anybody used ebay mounts with b18b1 in a 91 EF? I need help, will I need the iron piece that goes on the block with the offset bolt holes on the driver side or the one with holes that are in-line with each other? Any pictures will help thanks
