94 civic hatch TS. whole car or part out.
parting out my brother TS car. going rwd. car still is completely together and running if anyone is interested in buying the whole car
any questions call or text 954-907-0520
EVERYTHING IS BASICLLY BRAND NEW. HAS ONE DYNO SESSION! MOTOR MADE 800 ON 27 LBS!
ENGINE
SHORTBLOCK---- 3000
AEBS B18C5 BLOCK
CUSTOM CP PISTONS 11:3:1
UPGRADED WRIST PINS
MANLEY TURBOTUFF RODS
BALANCED LS CRANK
ARP STUDS
ATI DAMPER
ALL MACHINE WORK DONE BY TEC IN RIVERA BEACH
CYLINDER HEAD
B18C1 P72 HEAD SUPERTECH COMPLETE VALVETRAIN- 600
POLISHED VALVE COVER $75
SKUNK2 PRO1 CAMS $450
GOLDEN EAGLE INTAKE MANIFOLD-550
EDELBROCK 75MM THROTTLE BODY-200
T1 STYLE CATCH CAN WITH LINES AND FITTINGS $250
AVID RACING SOLID MOUNTS $225
CX RACING RADIATOR IN MINT CONDITION $75
TRANSMISSION
B18C JDM GSR TRANS.-450
TILTON TWIN DISC WITH 7 LB FLYWHEEL-1000
QUAIFE LSD-600
TURBO KIT
CUSTOM TOP MOUNT MANIFOLD- 600
T4 62/65 PRECISION TURBO. .81 REAR-650
2 TIAL MVS RED WASTEGATES- 220 EACH
3 INCH PIPING BACKDOOR WITH BIG 4.5” –INTERCOOLER (FOR EG) 600
TIAL BOV- 150
3 INCH DOWNPIPE- 100
FUEL
2200 HIGH IMPEDEANCE BOSCH INJECTOR- 650
TWIN BOSCH 044 PUMPS WITH BRACKET AND ALL LINES AND FILTERS. FROM SUMP TO FUEL RAIL- 550
AEROMOTIVE REGULATOR $100
SHELL-5,500
94 CIVIC HATCHBACK
CUSTOM 10PT CHROMOLY CAGE
JOJO CALLOS CARBON FIBER 3 PIECE FRONT
SIEBON CARBON FIBER DOORS
CUSTOM DRAG WING
KIRKEY ALUMINUM SEATS (2)
SPARCO STEERING WHEEL
STROUD PARACHUTE ALL SETUP
STROUD WINDOW NET
GFORCE HARNESS
SWITCH PANEL (START,IGNITION,FUEL,FAN)
JDM CLUSTER
CNC STAGING BRAKE
SUMPED TANK
WHEELS-
STANCE MINDSETS ON 275-50-15 MT RADIALS WITH ONLY 10 DYNO PULLS 195-15’S ON THE REAR-850
SLICKS- EXOSPEED (LENSOS) ON 24.5” MT SLICKS- 450
ELECTRONICS
HONDATA S300 WITH BOOST CONTR. $550
AEM WIDEBAND SOLD!
MSD 6AL WITH BLASTER COIL $150
OEM DIZZY $150
BLUE NGK WIRES $40
AEM 5 BAR MAP SENSOR $80
FAL FAN $150
i'll get more pics up later today
ENGINE
SHORTBLOCK---- 3000
AEBS B18C5 BLOCK
UPGRADED WRIST PINS
BALANCED LS CRANK
ARP STUDS
ATI DAMPER
CYLINDER HEAD
TRANSMISSION
QUAIFE LSD-600
TURBO KIT
TIAL BOV- 150
FUEL
SHELL-5,500
94 CIVIC HATCHBACK
CUSTOM DRAG WING
STROUD WINDOW NET
GFORCE HARNESS
JDM CLUSTER
CNC STAGING BRAKE
SUMPED TANK
WHEELS-
ELECTRONICS
AEM WIDEBAND SOLD!
OEM DIZZY $150
BLUE NGK WIRES $40
FAL FAN $150
