car only runs with spark plugs backwards
Ok so I have a 99 gsr and I did a b20 vtec. I set it to tdc and out it all back together and it wouldn't start. So I was told to flip wires 1 and 4, and 2 and 3 and it started right up perfectly. So I tought I set tdc 180 degrees out so I pull off the timing belt off and reset it but still off same thing. Will it hurt the engine if I leave it like this? It runs perfect just weird. Or is there a way to flip the alternator to fire differently? I heard of someone doing this but can't find how. Thanks
Here is a video showing how the wires are on backwards and its keeling. I understand the firing order is backwards. But if I set them the proper way it doesn't even try to turn on just cranks. Like if timing was 180 degrees off. Im so confused on why it idles and runs with the firing order backwards.
http://www.youtube.com/watch?v=1lzD4...e_gdata_player
that is strange. but yes, it will harm the engine if run like that for a long period.
there is something wrong with your timing for sure. pull the valve cover and check cam and crank sync
actually, a better way to do this is to pop off your distributor cap, rotate crank to #1 tdc, and check location of the rotor. it should be pointed at #1. where #1 is SUPPOSED to be. if not, either the cam and crank are out of sync, or you've installed the distributor 180* out. i have a feeling, since you checked mechanical timing, that the latter is the culprit. which is odd, because it should take great difficulty to do this, since the ears on the cam are notched so this doesn't happen. did you have a hard time getting the distributor to seat?
Ok so I figured it out. I guess my alternator was actually 180 out so that's fixed. But now car revs fine but wont idle. Does the throttle cable have to have a little pressure so that the car idles? On check engine lights are for o2 and oxygen content.
have you checked for codes? check regardless of an illuminated MIL
Haven't driven it so haven't warmed it up. Its not tunned yet so didn't want to drive it till it was tuned. And my check engine light is on for oxygen content and primary o2 sensor. Should I just put a little tension on the throttle cable so that it idles at 800?
What are the specific alpha-numeric codes that have been stored? There are several possible codes, not all related.
Your throttle cable MUST have between 3/8" and 1/2" of free, loose deflection in the exposed cable when you wiggle it with your fingers. It must NOT be tight!
There is to a code for "oxygen content" I have codes 1- oxygen content, and 41-o2 heater both of which whole not affect idle. Ill check on the idle screw and mess with it
Code 41 could mean a couple of different things as well.
Or you could find out how to adjust the idle properly. I don't know the exact procedure for your model, otherwise I'd tell you. The procedure varies slightly with the years.
Tuned, what is your set up? I have heard when people install aggressive cams it will need a decent amount of tuning to sustain an idle...... But for some reason I am thinking yours is just a standard B20V setup. Your TPS could be bad as well?
No car is not tunned just got it runing with the new motor. And I figured out why it wouldn't idle. I had the iacv and temp sensor on backwards lol idles perfect now. Set up is stock b20 bottom end with stock gsr head. Neukin ac ramhorn garret 57 trim. Tial bov and wastegate. Hopping for 300-350 whp
doppler
11
Sep 4, 2004 06:48 AM
sodacan33
12
Jun 22, 2004 08:47 PM
